CTS Turbo
Old 04-12-2017, 04:35 PM   #133
bon qui qui
Formula 3000 Driver
bon qui qui's Avatar
Drives: '06 GTI / '17 Taco
Originally Posted by xSabretoothx View Post
When's the ETA on completion?
Not sure. Too many other projects going on currently, but should hopefully be working on it again in about two weeks or so.
bon qui qui is offline   Reply With Quote
Old 04-13-2017, 06:44 AM   #134
clownish
just clowning around
clownish's Avatar
Drives: Mk5 R32
Rad build tho; what tuner are you ending up with?
clownish is offline   Reply With Quote
Old 01-24-2018, 07:14 PM   #135
bon qui qui
Formula 3000 Driver
Looked at this thing yesterday
Also trying to work with Eric to get some vacuum pump delete plates made, 3D printed one to close off the hole in my car.
Sorry for the terrible pictures, my car is in a trailer and it was dark.
Old 01-24-2018, 07:54 PM   #136
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
This needs to be done before shows start in the spring. It’s soooo close
eurocars is offline   Reply With Quote
Old 01-25-2018, 09:46 AM   #137
xSabretoothx
Fast w/ training wheels
xSabretoothx's Avatar
Drives: Better Than You
You and I will probably get done around the same time, you are only a stone's throw away. We should get together and maybe do a 'Humble Mechanic' or 'DAP' video.
"You can never get enough of the things you don't need, because the things you don't need can never satisfy."
Marvin J. Ashton
xSabretoothx is offline   Reply With Quote
Old 01-25-2018, 11:16 AM   #138
bon qui qui
Formula 3000 Driver
That'd be pretty cool. I'm hoping to have my car done to have in our booth at European Experience.
Old 03-14-2018, 10:32 AM   #139
eurocars
eurocars's Avatar
Drives: GTI
bump
Old 03-14-2018, 12:22 PM   #140
bon qui qui
Formula 3000 Driver
Indeed. Come see it in our booth at EuroEx.
CMP, VIR, AMP, Watkins Glen, Daytona, NCM, Road Atlanta
Old 03-14-2018, 01:23 PM   #141
xSabretoothx
WHAT?? I thought it was never going to happen.
Marvin J. Ashton
Old 03-14-2018, 03:01 PM   #142
bon qui qui
Formula 3000 Driver
You and me both.
Old 03-16-2018, 12:40 AM   #143
bon qui qui
Formula 3000 Driver
Old 03-22-2018, 06:10 PM   #144
bon qui qui
Formula 3000 Driver
So this past weekend got some more work done on this thing.
We made a coolant reservoir, it has a -6 hose for the bleed, a -12 for the feed, two -4's for the sight glass, and a mishimoto 19psi radiator cap. It was made from a mishimoto coolant overflow.
It's going to be installed on the strut tower near the fuse box.
All of the oil lines (except the ones on the turbo) are in black braided AN hose, and I have this black with blue trace for all the coolant lines (again except for those to the turbo).
Also changed the coolant pipes to the thermostat to have AN fittings.
What the lower pipe looks like on the thermostat housing.
Old 03-22-2018, 06:55 PM   #145
eurocars
eurocars's Avatar
Drives: GTI
I like the diagram on the Motul paper
Old 03-22-2018, 10:18 PM   #146
bon qui qui
Formula 3000 Driver
I'm an artist, what can I say.
Old 03-23-2018, 11:22 AM   #147
bon qui qui
Formula 3000 Driver
Friend of mine made me a vacuum pump delete.
It's not pressed all the way in, but will sit flush when fully installed.
Old 03-23-2018, 09:30 PM   #148
projectDIY
Drives: Golf Mk5 Gti
Loving both yours and Erics builds. Paving the way for probably the most custom modified tfsi setups ive seen.
I bought some of Erics old rad hardpipe setup and I'm looking at running a coolant overflow similar to yours. I can't quite figure out were to run the bleed line from and the feed line to? I'm assuming one goes from a port on the upper rad hose?
projectDIY is offline   Reply With Quote
Old 03-26-2018, 09:53 AM   #149
bon qui qui
Formula 3000 Driver
The bleed line goes form the highest part of that upper pipe, and the feed goes down in to the thermostat housing. I cut the pipes to the thermostat housing and welded on an AN fitting to run a -12 AN hose from the tank to the thermostat housing.
Torqued and marked everything to do with the subframe except the control arm bolts up front (wrong bolts are in there currently). I'm also holding off on installing the aluminum control arms and spindles until everything else is done.
Old 03-26-2018, 10:14 AM   #150
xSabretoothx
Random question, what bushing are you using in your BSH pendulum mount?
Marvin J. Ashton
Old 03-26-2018, 11:27 AM   #151
bon qui qui
Formula 3000 Driver
The one in the subframe is the Volkswagen Racing one, the one in the pendulum itself is the delrin one that Eurocars made a while back.
Old 03-26-2018, 11:28 AM   #152
bon qui qui
Formula 3000 Driver
Also got the downpipe made this weekend.
Old 03-26-2018, 01:11 PM   #153
eurocars
eurocars's Avatar
Drives: GTI
Dont forget a hangar at the subframe
Old 03-26-2018, 02:53 PM   #154
vwengineer
FIA World Rally Car Newbie
vwengineer's Avatar
Drives: Golf 5 GTI (stock AXX)
So cool! I thought the whole project had been abandoned (only saw the videos). Good luck!
vwengineer is offline   Reply With Quote
