Parts4Euro
Old 05-16-2014, 10:51 AM   #1
mnathanielc
Reader
mnathanielc's Avatar
Drives: 2007 GTI 4dr BMP
mnathanielc's BMP 07 GTI
Hello all,
I'm not a fan of a thread for every single thing you do with your car, so the plan is for this single thread to contain all that I ever do with this car.
History:
My first car was a 93 accord. I owned it from 2004-2013.
Then Dec 2013 I traded it in for this lovely 2007 GTI.
Car details:
Black Magic Pearl
DSG
4DR
125K mi
From what I can tell it's all stock besides the cheap 16s the previous owner put on it, and tinted windows.
And I have no idea what the maintenance history is.
So I'm going to be doing as much of the standard maintenance as I can to establish a history and ensure a reliable fun car.
Done so far:
-Oil change (Liqui Moly & Mann filter)
-Seated the headlight bulbs which weren't attached to the headlight housing at all, whoever touched them last obviously had no clue what they were doing.
-Looked over the car for issues. Found the following:
-d2s bulbs are different color temperatures.
-Driver side mirror indicator is out.
-Squeaking on the timing belt side
-Oil on top of valve cover, and here and there around, wiped off to see where it reappears.
-Tear in driver side CV boot
-Checked cam follower
-Busted up front grill
-Broken rear wiper arm
I decided to just assume the car has not been properly maintained for a while.
Parts I have ordered:
-ECS Ultimate Plus Timing Belt Kit
-ECS Cam Follower Replacement Kit
-Genuine DSG Transmission Service Kit
-Cabin filter
-Air filter
-Fuel filter
-Set of Bosch spark plugs
-Raxles drivers side axle (Marty is a really nice guy)
-Ross Tech VCDS License with Micro-CAN cable
-Misc tools
mnathanielc is offline   Reply With Quote
Old 05-16-2014, 04:33 PM   #2
mnathanielc
Reader
Look what just showed up.
No fun car mods, but hey, a well running car is a fun car.
Old 05-17-2014, 07:29 PM   #3
Jkdesigns
Drives: 2007 gti 4 door
Nice! Did you get new coils as well?
Jkdesigns is offline   Reply With Quote
Old 05-17-2014, 08:10 PM   #4
SuperSkyline89
Das Schiesse
SuperSkyline89's Avatar
Drives: 2008 CW GTI
You definitely want a well running car before pouring thousands of dollars into mods. You can have the nicest parts you want but people will still focus on what's broken and it'll tear you up inside.
2008 GTI Build Thread
Volk Racing | StopTech | HPA Motorsports
KW Suspensions | Whiteline | Integrated Engineering
SuperSkyline89 is offline   Reply With Quote
Old 05-17-2014, 08:10 PM   #5
mnathanielc
Reader
Not yet, running low on funds and I still have to diagnose if I need to replace the valve cover or just the gasket to fix the oil leak.
Old 05-18-2014, 12:52 AM   #6
mnathanielc
Reader
Exactly. A set of wheels and springs would look great. But I'd rather be driving reliably than looking great on the side of the road.
Old 05-19-2014, 05:15 PM   #7
mnathanielc
Reader
Air filter was definitely due for a change. Also changed the cabin filter and a small pile of leaves and junk fell out when I removed the old filter.
Pulled the coils out today. Thankfully there's no oil on them.
I'm beginning to suspect the valve cover being responsible for the leaks.
I feel like if it was just a bad gasket there would be oil in the spark plugs, not only coming up a few of the screw holes, base of the oil cap, and out the back.
Not sure if anything else is leaking, or if it's all just running down from the top.
Maybe someday I'll have money for aesthetic things like the busted grill.
Old 05-28-2014, 08:44 AM   #8
mnathanielc
Reader
Swapped out this little guy.
Did the fuel filter at the same time, worked out really well, had very minimal amounts of fuel come out of the fuel lines as I disconnected them from the old filter.
And the driver side axle.
By the way, Marty at Raxles is really a pleasure to do business with, really friendly, great price. Can't really beat better than OEM quality for less than OEM cost.
Old 05-28-2014, 09:07 AM   #9
mnathanielc
Reader
Had some fun with VCDS.
Remote windows up and down.
Fogs as DRL.
6 light brights.
Random picture: moody rain lighting.
Old 05-28-2014, 01:00 PM   #10
SuperSkyline89
Das Schiesse
Drives: 2008 CW GTI
Is there an option to enable the sunroof to open and close with the windows?
Old 05-28-2014, 01:06 PM   #11
mnathanielc
Reader
The option is in there, but it doesn't work to open the sunroof, you can close it though. On my wife's 2012 Jetta the sunroof does open with the remote, so I guess it's a limitation or bug for our cars.
I haven't looked into it any further, I'm happy with being able to open the windows, and I'm glad it'll close everything.
Old 05-28-2014, 01:08 PM   #12
SuperSkyline89
Das Schiesse
Drives: 2008 CW GTI
Thanks for the info.
I'm glad there's at least an option to close it, I literally never drive without both windows and the sunroof open in the summer so being able to close it all from outside is better than just the windows.
Old 06-07-2017, 03:44 PM   #13
mnathanielc
Reader
Been awhile, here's how it's looking from the other day after a wash, a new driver door lock module and rear hatch harnesses.
Old 06-07-2017, 03:54 PM   #14
mnathanielc
Reader
In case you were wondering, it is possible to replace the hatch harness without splicing the third brake light cable.
The brake light plug is in a rubber grommet so you can flex it around to get it at the right angle to get a small flat screwdriver in to release the old one.
Then I had to enlarge the holes on either side so my pointer fingers could fit to have the strength to maneuver and plug in the new connector. Only my pinky fingers could fit through the stock holes.
Don't forget to smooth the freshly cut edges with a file and put some paint over the bare metal.
It's a bit of a pain, but worth it to know your brand new harness is fully intact.
Old 08-08-2017, 05:12 AM   #15
amyburgess121
amyburgess121's Avatar
Drives: GTI
He is very handsome. I love. Interesting is the factory equipment?
If you want pay for homework and that it is done for you, then we will do it
amyburgess121 is offline   Reply With Quote
