Old 05-11-2016, 01:33 PM   #133
ErBall
Measurement Mogul
ErBall's Avatar
Drives: Rolling burnouts
DEI Titanium.
Build Thread
ErBall is offline   Reply With Quote
Old 05-11-2016, 01:46 PM   #134
avenali312
Formula 5000 Champion
avenali312's Avatar
Drives: 2015 GTI
Originally Posted by ErBall View Post
DEI Titanium.
Thanks, it looks really great.
Originally Posted by merkeyterkey View Post
So today I just walked right into Mordor.
I don't have pictures or directions, it was pretty neat though.
avenali312 is offline   Reply With Quote
Old 05-11-2016, 02:21 PM   #135
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
It looks great man, hopefully you can put in the road soon and let us know your feedback and differences between the 5858 & gtx30
Mostic is offline   Reply With Quote
Old 05-18-2016, 05:29 PM   #136
xSabretoothx
Fast w/ training wheels
xSabretoothx's Avatar
Drives: Better Than You
Do work!
"You can never get enough of the things you don't need, because the things you don't need can never satisfy."
Marvin J. Ashton
xSabretoothx is offline   Reply With Quote
Old 02-25-2017, 08:11 PM   #137
Joshohol
FIA GT Champion
Drives: 07 Candy White Gti
Updates¡!?!?
Sent from my SM-T350 using Tapatalk
Joshohol is offline   Reply With Quote
Old 02-25-2017, 09:02 PM   #138
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
It's broken right now. Trying to help troubleshoot
eurocars is offline   Reply With Quote
Old 02-25-2017, 09:28 PM   #139
Joshohol
FIA GT Champion
Broken?!
Old 02-25-2017, 09:45 PM   #140
eurocars
eurocars's Avatar
Drives: GTI
#1 plug is fouling due to overfueling
Old 02-28-2017, 01:51 PM   #141
ErBall
Measurement Mogul
ErBall's Avatar
Oh man, I forget about this thread for months at a time.
So as Eric stated, the car is currently down. Not that I haven't been working on it and driving it on and off for the past year or so.
I've done a few things since the last update.
- Swapped to a tial .63 turbine housing. Spool has improved massively. Went from 25psi at 5100 to 25 at 3900rpms. I can tell there isn't as much up top, but the driving dynamics are so improved I could care less.
- Replaced the Bosch 044 with an AEM 320lph in the surge tank. Redid all the lines with OEM style pushloc fittings.
- Swapped out to ZZP LDK injectors from the LNF injectors.
- Ordered Eurodyne Meastro, have yet to flash ecu for reasons.
So injector one is overfueling and giving a decent amount of misfire codes, with enough fuel being sprayed to actually wash down the intake valves and going into the intake manifold. This is the whole reason I replaced the injectors in the first place, thinking I had a bad one. All the injector wiring appears to be solid, with no shorts in the system I can find. Continuity is good, and resistance is uniform across the board on injectors and harness. Brand new coilpacks and spark plugs also.
I did a compression check and found 110-120 psi across the board. Within wear limits, but lower than I expected given I re-ringed the engine at rebuild. I've ordered a leakdown tester and will find out more on that front hopefully soon.
So yeah, tons of fun /s. If I have more issues i'll probably sell the car or part it accordingly. I REALLY want a new A3.
I've had 3 different tunes on this ECU, so it's possible it's a injector driver (per erics help), but I'm not willing to go down that route till I've exhausted everything else.
Build Thread
Old 03-01-2017, 09:37 PM   #142
Criz90
enjoying BT
Criz90's Avatar
Drives: 09 UG Gti
What's your review on the etuners tune?
351whp 358wtq
Criz90 is offline   Reply With Quote
Old 03-08-2017, 12:08 PM   #143
eurocars
eurocars's Avatar
Drives: GTI
Since he never updates this thread, turns out the issue was a faulty brand new spark plug causing misfires. New plug is in and no more misfires
Old 03-08-2017, 12:09 PM   #144
Joshohol
FIA GT Champion
Wow! Glad he got it figured out
Sent from my SM-N920P using Tapatalk
Old 03-09-2017, 12:29 AM   #145
high_octane3541
Formula 5000 Driver
high_octane3541's Avatar
Drives: 08 MkV GTI / 2016 S3
So the injector was never the issue?
B00ST!!!
IG: high_octane3541
high_octane3541 is offline   Reply With Quote
Old 03-09-2017, 10:50 AM   #146
eurocars
eurocars's Avatar
Drives: GTI
Nope, plug wasnt firing causing and was allowing fuel to pool on it, making it look like an overfueling injector.
Old 03-09-2017, 02:37 PM   #147
kern417
Touring Car Champion
Drives: '09 GLI
good to hear
kern417 is offline   Reply With Quote
Old 03-09-2017, 05:00 PM   #148
high_octane3541
Formula 5000 Driver
Ohhhhhh good to know
B00ST!!!
IG: high_octane3541
Old 05-11-2018, 12:55 PM   #149
AnthonyScoks
Newbie
Drives: Man
Send a message via ICQ to AnthonyScoks Send a message via AIM to AnthonyScoks Send a message via Yahoo to AnthonyScoks Send a message via Skype™ to AnthonyScoks
ErBalls Thunderbunny Build log
Lucky you reserved your own build thread, someone else might have started it first...
AnthonyScoks is offline   Reply With Quote
Old 05-11-2018, 01:08 PM   #150
nagami
Drives: m5
looks good
nagami is offline   Reply With Quote
