Old 03-31-2014, 12:10 AM   #45
high_octane3541
Formula 5000 Driver
high_octane3541's Avatar
Drives: 08 MkV GTI / 2016 S3
Yeah :(
Gonna upgrade some parts while the head is off though :D
B00ST!!!
IG: high_octane3541
high_octane3541 is offline   Reply With Quote
Old 03-31-2014, 12:41 AM   #46
Das Gespenst
Formula 3000 Champion
Das Gespenst's Avatar
I feel for ya man, that really sucks! Been a while since a build like this has been around, very glad to see some epic fresh builds. Sounds like you are doing it right to. On the bright side, you have an excuse to build the top end lol. I have to say, the HPA intake manifold would look soooo slick in there! Also helps with new w/m locations and lets that turbo really push air, bottoms already built and your going for some good numbers. Freeing up that last choke point really does help.
Sick build man, props regardless!
Old 03-31-2014, 01:40 AM   #47
Barrett
veeeeeduuub
Barrett's Avatar
Drives: 08' UG GTI / DSG
go texas yeaaaaaaaaa :D
[2 dr, United Gray, DSG, Autobahn PKG, Huffs, Tint, Eurojet Catback Exhaust, NEUSPEED P-Flow Intake, Yellow & Open Fogs, Color-matched Sidemarkers, 10in Kenwood Sub]
Barrett is offline   Reply With Quote
Old 03-31-2014, 08:35 AM   #48
high_octane3541
Formula 5000 Driver
Thanks man!
B00ST!!!
IG: high_octane3541
Old 03-31-2014, 12:58 PM   #49
RRacerguy717
FIA GT Newbie
Drives: 06 GLI
Originally Posted by high_octane3541 View Post
Yeah :(
Check the turbo espec the turbine wheel make sure small pieces didn't damage the wheel , deff heat related failure could have been poor coolant flow around the head from that pinched off rad hose.
Hopefully nothing else got damaged look it over good and good luck on your rebuild. Bob G
Don't waste your hard earned money on APR Stage 3 kit look here. http://forums.vwvortex.com/showthrea...ge-3-dyno-runs
RRacerguy717 is offline   Reply With Quote
Old 04-01-2014, 02:32 AM   #50
kern417
Touring Car Champion
Drives: '09 GLI
good luck on the rebuild
kern417 is offline   Reply With Quote
Old 04-01-2014, 08:28 PM   #51
high_octane3541
Formula 5000 Driver
Well looks like the cyl walls are too damaged to just hone. Will be boring it out to 83mm
B00ST!!!
IG: high_octane3541
Old 04-01-2014, 08:29 PM   #52
high_octane3541
Formula 5000 Driver
My PTE5858
B00ST!!!
IG: high_octane3541
Old 04-05-2014, 07:11 PM   #53
high_octane3541
Formula 5000 Driver
B00ST!!!
IG: high_octane3541
Old 04-07-2014, 05:48 PM   #54
high_octane3541
Formula 5000 Driver
IE goodies
B00ST!!!
IG: high_octane3541
Old 04-07-2014, 06:30 PM   #55
flat tire
Formula 5000 Driver
Drives: Electric + 135i
IE goodies
What's the reason for using this?
flat tire is offline   Reply With Quote
Old 04-07-2014, 07:00 PM   #56
high_octane3541
Formula 5000 Driver
Cam gear - eye candy
Timing gear - just for that piece of mind
B00ST!!!
IG: high_octane3541
Old 04-08-2014, 09:18 AM   #57
613B6
Rally Car Champion
613B6's Avatar
Drives: GTI
Have you figured out why the chuck of valve broke off? Piece of carbon fly off?
Eurodyne remote tuning
IG: 613B6
613B6 is offline   Reply With Quote
Old 04-08-2014, 09:53 AM   #58
high_octane3541
Formula 5000 Driver
Not yet :/
Takin the block, head and crank to my tuner Thursday so he can take it to the machine shop
B00ST!!!
IG: high_octane3541
Old 04-08-2014, 09:53 AM   #59
high_octane3541
Formula 5000 Driver
On a side note. Who on here is running a ttrs lpfp?
B00ST!!!
IG: high_octane3541
Old 04-08-2014, 07:19 PM   #60
Bunnspeed
Salad Tosser
Bunnspeed's Avatar
Drives: 2008 UG GTI 4 door
ROH ECHT is.
R.I.P. 6MT 5 door GTI K04
White 1997 Cadillac DeVille
a.k.a. The Marshmallow Warhammer
Bunnspeed is offline   Reply With Quote
Old 04-14-2014, 08:31 PM   #61
high_octane3541
Formula 5000 Driver
Started cleaning the bay some while I wait for my parts to come back from the machine shop.
Oil stains from vta can :/
B00ST!!!
IG: high_octane3541
Old 04-15-2014, 11:15 AM   #62
boki
FIA World Rally Car Champion
Drives: LB '09 GLI K04 APR
Damn, sorry to see this...could it be that the timing belt skipped a tooth or two somehow?
boki is offline   Reply With Quote
Old 04-15-2014, 12:42 PM   #63
LukeHS3
LukeHS3's Avatar
Drives: GOLF ED30
same thing happend to mine but only on 1 cylinder
MKV ED30
GTX30
511hp
LukeHS3 is offline   Reply With Quote
Old 04-15-2014, 06:47 PM   #64
high_octane3541
Formula 5000 Driver
Not sure. I know the previous night of the tuning my tuner said it was pulling almost 12 degrees
B00ST!!!
IG: high_octane3541
Old 04-15-2014, 06:49 PM   #65
high_octane3541
Formula 5000 Driver
Update: should have the block and head back from the machine shop by the 28th
Will be installing ferrea exhaust/ intake valves and IE springs/retainers
B00ST!!!
IG: high_octane3541
Old 04-15-2014, 07:07 PM   #66
RRacerguy717
FIA GT Newbie
Drives: 06 GLI
Pulling 12 degrees cw knock? Or 12 degree total timing?
If it was pulling 12 degrees knock and he let you drive out with that tune on your car find another Eurodyne capable tuner B4 he wrecks your new engine. Bob G
