Old 04-21-2019, 04:51 AM   #1
irishbaz
Drives: MK5 GTi Graphite blue
TT arms and ball joints
Hey guys I fitted the anti lift kit and tt arms to my mk5 GTI yesterday. The camber is way off with the TT ball joints.
Do u guys know if there is enough adjustability in these to align the car ? I'm on standard springs and dampers.
Is anyone else running this setup?
irishbaz is offline   Reply With Quote
Old 04-21-2019, 05:00 AM   #2
irishbaz
Old 05-20-2019, 01:59 AM   #3
Brigand
Newbie
Brigand's Avatar
Drives: 2006 MKV GTI
Iím not running this setup but have read that this introduces more negative camber. I believe you will have -1.5 degrees minimum with the option of dialing in more (like 1 more degree).
Brigand is offline   Reply With Quote
Old 05-20-2019, 09:21 AM   #4
irishbaz
I got this setup aligned and it's about 1.5 degrees of neg camber. I also got adjustable arms on the rear which I'm fitting shortly.
I got some poly bushings to go in the rear also just searching for a tool to remove the old bushings before I get into that job.
