Old 10-15-2013, 04:18 AM   #23
polo classic
Oval Champion
polo classic's Avatar
Drives: 09 Scirocco 1,4 TSI
Send a message via MSN to polo classic
Originally Posted by EvoIII View Post
Did you have your brackets for the rear custom made?
xola3que here that had them made
http://golfmk5.com/forums/showthread...hlight=Cayenne
polo classic is offline   Reply With Quote
Old 10-16-2013, 05:05 AM   #24
penance
Fakinsupa
penance's Avatar
Drives: '07 GTI BMP 2DR
No, Xolaque made them years back - 2009ish.
Brake balance feels pretty even to me - very noticable improvement over stock. I'm on the OEM booster - seems more than fine for daily and emergency situations. I want to do the booster upgrade eventually (TT, I think), but the car is fine without it so I'm not in a rush. Whenever I find a good used one I'll do it.
I've had some near crashes (Vancouver drivers, ugh!) and these have performed exceptionally. Stops fast.
Originally I was going to go label-less on the calipers (used repainted), but I got a deal I couldn't pass up on new ones from a dealer... so I just left them as-is.
penance is offline   Reply With Quote
Old 09-07-2018, 05:19 PM   #25
Carkiller99
Drives: Golf Mk6 TDI
Trial complete on front. For the factory detroit 18 inch wheel the minimum sized spacer to use is an 8mm(H&R) with the Brembo 355x32, 6 piston kit. This is for a vehicle with VWR sport springs. It clears the calipers by about 2mm. I currently have 5mm spacers on the rear but will try 8mm as well. Spacers larger than 8mm caused the wheels to hit the fender when encountering larger bumps.
Also as an aside, one does not require longer studs. You may choose to use longer Porsche 19mm wheel bolts that come in longer lengths and are black.
19x8j tallageda Et 51 can i use with z18 BBK!? Doese somebody try this.?
Sent from my iPad using Tapatalk
Carkiller99 is offline   Reply With Quote
Old 09-07-2018, 07:36 PM   #26
GIACUser
Master Wallet Mechanic
GIACUser's Avatar
Drives: 2008 UG EFR7163
After installing my 18z calipers I measured and made a template. These measurements may come in handy for some of you.
2008 GTI EFR7163 - 480whp
Old 07-15-2019, 01:46 AM   #27
S T
S T's Avatar
Drives: VW MK5 GTI DSG (2006)
Originally Posted by JanK View Post
I have a 10mm spacer I believe on my 18" detroits. I have the StopTech BBK 328 x 28mm.
No issues of rubbing the fenders with 10mm? I was thinking of using 12mm all round
S T is offline   Reply With Quote
Old 07-15-2019, 01:46 AM   #28
S T
S T's Avatar
U got pics to show pls?
