Old 12-13-2017, 07:23 PM   #67
gti2slow
Formula 5000 Driver
gti2slow's Avatar
Drives: 2008 GTI UG 6MT
Nothing needs removed from the cast steel or aluminum (Passat) lower control arms. The stamped ones will gouge the surface at full lock.
You need 12.5mm spacers with denver/huffs/detroit wheels for the 17z calipers. I doubt the mk7 austins will clear with only 5mm.
Driver Motorsport K04+ | RFD | EJ FMIC | EJ 3" Turboback | Peloquin LSD | SRE clutch
Neuspeed P-Flo | IE catch can | Brembo 17z BBK | Neuspeed RSe12 | RB 2-piece rotors
.:R32 Rear bumper | Votex lip | Koni coilovers | RCD510 | S3 short shifter | APR HPFP
gti2slow is offline   Reply With Quote
Old 12-13-2017, 07:52 PM   #68
Pissat4motion
Time Lord
Pissat4motion's Avatar
Drives: 2004 Passat(sold); 2007 GTI
Cool. I'll plan on swapping over to the Passat LCAs at the same time then.
Guess I'll have to look at sourcing some spacers and longer wheel bolts also... that sucks.
DM K04+/Golf R K04/neuspeed cai/APR DP w/hiflo cat/WRD coilovers/18x7.5 mk7Austins+15/20mm spacers/034 aluminum dogbone insert& AUDUB trans mount/Custom catch can w/ 42dd adapter plate/Unitronic DV Relocate/ JH Motorsport HPFP internals/Euro short shifter/R map sensor/Golf R Intercooler[b]/17z BBK/mk6 climatronic/BFI billet heavyweight shift knob/mk6 GTI flat bottom sw
Pissat4motion is offline   Reply With Quote
Old 12-27-2017, 07:51 PM   #69
Pissat4motion
Time Lord
Finally got mine installed today. Clearance is tighter than a mug.. but I'm happy with them so far
Sent from my Nexus 6 using Tapatalk
Old 12-27-2017, 08:45 PM   #70
gti2slow
Formula 5000 Driver
gti2slow's Avatar
12.5 or 10mm spacer on those austins?
Old 12-28-2017, 07:15 PM   #71
Pissat4motion
Time Lord
12s.. didn't think that .5mm would matter much but .. it's close.
Thinking about it, I was initially looking for 15s. Still may swap to 15s at some point and that would give at the very least 2mm of clearance.
Old 12-28-2017, 08:44 PM   #72
gti2slow
Formula 5000 Driver
gti2slow's Avatar
The wheel bearing will have some play and your wheel may flex, when I was looking at BBK's the manuals for a few said that 3mm clearance was the absolute minimum clearance.
You are still a bit tucked with them so 15mm spacers may get you moar flush. I've been able to push Denver's out pretty far and not eat my fenders, but I am not low enough for stance nation.
Old 02-03-2018, 05:35 PM   #73
Pissat4motion
Time Lord
Ive been running the 12mm spacers for over a month with no issues but I was just waiting for a pair of 15mm spacers to come up for sale. Got a pair installed and I don't feel as though I'm a nasty bump away from catastrophe lol.
Old 04-05-2019, 04:23 PM   #74
escottc
Newbie
Drives: 2010 VW GTI Mk6
Hub Centric Ring
Thank you for the information. I've found another post that mentioned that Hub Centric Rings need to be "shaved" a bit to fit. Is that needed for the 17z? Thank you. - Scott
escottc is offline   Reply With Quote
