Old 08-05-2012, 11:18 PM   #23
phillip1978
Touring Car Champion
Drives: Golf GTi mkV 2007 MY08
I only did a quick search on google
"hubcentric rings"
There seems to be heaps of companies out there that do this, i am bit skeptical of rings made of plastic aswell but i am sure there should be more companies out there that make rings from steel or aluminium alloy
phillip1978 is offline   Reply With Quote
Old 08-06-2012, 10:35 AM   #24
PatientlyWaiting
is waiting patiently
Drives: 2008.5 GTI CBFA
Parts on their way, about to take the plunge.
WFSU | switchedstance | Flickr | DON'T GO APR
PatientlyWaiting is offline   Reply With Quote
Old 08-06-2012, 11:04 AM   #25
tomshouse516
tomtomtomotomtomtomtomtom
tomshouse516's Avatar
Drives: Rattracker + Sketch10
I am about to order up the last few items for my setup this week.
tomshouse516 is offline   Reply With Quote
Old 08-06-2012, 11:08 AM   #26
PatientlyWaiting
Yay we can have a BBK party when you come home!
Old 08-06-2012, 11:37 AM   #27
tomshouse516
For sure
Old 08-06-2012, 12:01 PM   #28
PatientlyWaiting
I gotta replace the dust seals on mine, supposedly not that hard.
Old 08-06-2012, 05:09 PM   #29
PatientlyWaiting
Yea they are super cheap for the set like $20 or something, nbd.
I need to order my .:R rear brakes and I will be all set.
Yeah, I'm gunna do R rears when my rear rotors need to be replaced.
Old 08-08-2012, 01:21 AM   #30
phillip1978
Keep us informed on how your kit and install goes
Old 08-08-2012, 12:35 PM   #31
tomshouse516
I will update this thread with any and all info I learn from the install as well as pictures, measurments and preformance reviews.
Old 11-12-2012, 05:28 AM   #32
phillip1978
So how did your kit go?
Old 11-12-2012, 01:20 PM   #33
HemiAlex
FIA GT Newbie
HemiAlex's Avatar
Drives: 2009 GTI 6MT
Agreed...Bump..
HemiAlex is offline   Reply With Quote
Old 11-14-2012, 12:20 PM   #34
tomshouse516
Sorry I have been off the forums for a while, I moved and a ton of other things I am working on the follow up for this tread and will update it soon.
Old 11-19-2012, 06:38 PM   #35
ktm25089
Autocross Newbie
Drives: GOLF V
I have one set of 18z calipers.One friend have one set of new 345mm R32 front discs.Will this work?Because everywhere i see the ML type discs.
Thanks
George
ktm25089 is offline   Reply With Quote
Old 11-24-2012, 11:42 AM   #36
tomshouse516
Thanks
George
No you need 2008 GL450 rotors for those calipers
Old 11-24-2012, 11:58 AM   #37
tomshouse516
The brakes have been installed since mid september, they bolted right up with the parts listed with minimal effort. You have to do a little grinding on the caliper and control arm because they touch at full lock, when you test fit them turn to full lock and you will see where.
The braking force is phenomenal and immediate, I also installed a 328mm Brembo 4 piston rear kit to compliment the fronts and they are wonderful. Very modular, light pressure gets light braking heavier you go the harder they stop.
The rear kit was used and the caliper hung off the rotor quite a bit when I received them, I threw the brackets on a milling machine and relocated the mounting points 10mm to get the caliper to sit correctly.
Old 11-24-2012, 12:13 PM   #38
tomshouse516
I also added a few details to the first post and will post a mounted picture at a later date.
Old 11-25-2012, 05:49 AM   #39
phillip1978
Great work there, this kit sounds like one of the better DIY budget kits out there
Old 11-27-2012, 12:41 AM   #40
tomshouse516
I have about $830 into my entire front setup with all brand new parts
Old 11-27-2012, 04:43 AM   #41
phillip1978
Old 11-11-2013, 04:52 PM   #42
Elliott
Formula 2 Driver
Elliott's Avatar
Drives: BMP 07 MT MKV GTI
Can someone tell me what Porsche these are from?
They are 4 pot front and back.(large pistons not the smaller ones) I think cayenne but could be mistsken .
Picked these up for 250 so going to try make them work.
"meh" build thread
.My job is alloy wheel refurbishment so if anyone has any questions, ask away.
Check out my Facebook work page WheelFixItSpain.com.
n show your support.
Elliott is offline   Reply With Quote
Old 11-12-2013, 12:53 AM   #43
saddart
Drives: mkv
They are a from a 986 boxster. U can use them wif stock rotors size if u wanted to. There is a thread on it, on the uk gti website
saddart is offline   Reply With Quote
Old 07-19-2016, 01:22 PM   #44
Das Gespenst
Formula 3000 Champion
Das Gespenst's Avatar
Super old thread bump. I ended up using the 17z setup mentioned here with all correct hardware and hub rings. I'm having an issue with the rotors. They are ML350 rotors but they contact the ball joint and outer pad stop pins in the caliper. I for the life of me cannot figure out what the issue is, it's as if the rotors are just too thick since there's no way to move them inboard or outboard on the hub and it's contacting on both sides. Anyone have any ideas!? Any help will be appreciated.
