Old 04-26-2014, 10:18 PM   #23
Perpetuus
Data Encryption
Perpetuus's Avatar
Drives: 07 GTI MK5 6MT
Also picked up these bad boys today:
Íhlins | H2 Sport | Wagner Tuning | APR | AWE | Dieselgeek | VF Engineering | O.Z. | Wavetrac | VW Racing | H&R | Unitronic 2+
Perpetuus is offline   Reply With Quote
Old 06-09-2014, 10:35 PM   #24
Perpetuus
Data Encryption
Perpetuus's Avatar
Valve cleaning finished last month, at 34,XXX miles.
Before...
After...
K04 being installed. Drained all the coolant out today:
Old 06-10-2014, 10:19 AM   #25
phil
becausephilchow
Drives: 09 VW R32
Looks good
BECAUSERACECAR
phil is offline   Reply With Quote
Old 06-18-2014, 12:56 AM   #26
Perpetuus
Data Encryption
Perpetuus's Avatar
K04 being cleaned
Took the compressor housing off to clean the K04 before installing it
Old 06-19-2014, 04:39 AM   #27
Perpetuus
Data Encryption
Perpetuus's Avatar
K04 is installed!
Time to hook everything back up.
Old 06-28-2014, 10:57 PM   #28
Perpetuus
Data Encryption
Perpetuus's Avatar
Topped up with Redline 5W40 oil today
Mixed some coolant
Routed vacuum hose to DV
Old 06-29-2014, 09:50 PM   #29
Perpetuus
Data Encryption
Perpetuus's Avatar
Ran the car a little today while I refilled the coolant.
The idling is much smoother after the valve cleaner, but the car would stall on hard throttle. I assume the S3 injectors run too rich. Still waiting for tune... this week.
Also cleaned the VWR filter today.
Old 06-30-2014, 06:58 PM   #30
Perpetuus
Data Encryption
Perpetuus's Avatar
Some missing photos from my phone:
AWE DV, good for 650hp
S3 Injectors, assembled and ready to install
Noise Maker Device under the rain tray, removed.
Intake Manifold Support that I cut in half to free the intake manifold. The original triple square bolt (left) stripped. I replaced it with a 13mm hex bolt and it works great. Better access too.
Old 07-01-2014, 11:02 PM   #31
Perpetuus
Data Encryption
Perpetuus's Avatar
Bought a 90 degree elbow and silicone coupler to fit to my VWR intake.
After some cutting and fitting:
Also swapped to summer wheels and tires today:
Old 07-11-2014, 12:46 AM   #32
Perpetuus
Data Encryption
Perpetuus's Avatar
Neutralized the engine mounts today, and re-torqued everything.
Car is now quieter and passenger side headlight no longer vibrates while idling.
Exhaust is less crooked now too.
Old 07-26-2014, 05:29 PM   #33
Badas
Drives: MK5 1.9 TDI S
[quote=Perpetuus;3728958]Some missing photos from my phone:
What is this piece and what does it do? Also where EXACTLY is it in your car?
Cheers :)
Badas is offline   Reply With Quote
Old 07-26-2014, 05:34 PM   #34
Elliott
Formula 2 Driver
Elliott's Avatar
Drives: BMP 07 MT MKV GTI
Nice. Solid build.
"meh" build thread
.My job is alloy wheel refurbishment so if anyone has any questions, ask away.
Check out my Facebook work page WheelFixItSpain.com.
n show your support.
Elliott is offline   Reply With Quote
Old 07-26-2014, 07:26 PM   #35
goneD4rk
Drives: shortwagen
[quote=Badas;3734251]
Cheers :)
wth is this!
goneD4rk is offline   Reply With Quote
Old 07-26-2014, 07:50 PM   #36
Perpetuus
Data Encryption
Perpetuus's Avatar
Cheers :)
This is the noise amplification device. It attaches to the end of the noise pipe, and is underneath the rain tray on the right hand side of the car.
Old 07-26-2014, 08:13 PM   #37
goneD4rk
Drives: shortwagen
[quote=Perpetuus;3734269]
does not do sh1t as far as I can tell.
Old 08-16-2014, 07:49 PM   #38
Perpetuus
Data Encryption
Perpetuus's Avatar
Installed aluminium spindle to right front of my car today. Still need to do the other side tomorrow. The wheel bearing was a pain, everything else was easy.
Just had to make sure the nuts and bolts were the correct spec for these aluminium parts. The outer tie rod nut, 3x ball joint nuts, ball joint top nut, and the two 21mm brake bracket bolts were all different part numbers that were required.
100 N.m for the three nuts holding the ball joint instead of 60 N.m
200 N.m for the two 21mm brake bracket that bolts to the spindle.
Extremely Rusted Spindle
Scrubbed the Mating Surface Clean with a Wire Brush
Comparison of Aluminium Passat Spindle to stock GTI Spindle
After Install
Old 08-16-2014, 10:36 PM   #39
zrickety
The Fixer
zrickety's Avatar
Drives: 2009 GTI 6MT, 2010 GTI DSG
Great looking spindles...in for driving impressions.
Originally Posted by flat tire View Post
Figure out how to epoxy it and get rid of the car ASAP.
Originally Posted by dustinwark View Post
Smart man, unfortunately I am the friend with the tools.
Originally Posted by GIACUser View Post
I like that it looks rather mundane and sort of a commuter car but is really a wolf in sheeps clothing.
True ESP OFF on 08.5-09 cars: http://www.golfmkv.com/forums/showthread.php?t=190211
zrickety is offline   Reply With Quote
Old 08-17-2014, 12:12 AM   #40
phil
becausephilchow
Drives: 09 VW R32
How do you like them?
I got mine installed at the same time as my LCAs and everything, so I never got a chance to feel them just on their own when added.
BECAUSERACECAR
Old 08-17-2014, 01:01 AM   #41
Perpetuus
Data Encryption
Perpetuus's Avatar
I had the aluminium LCA installed on the right hand side for a week, and even with just that, I could feel the right hand side of the car was much more stable over the road, especially for sweeping turns that loads up the right front of the car. I could only imagine that adding the spindle would bring it up to another level! Will know by tomorrow when I do the left side too for sure.
After this, it's the BBK, which should save another 6 to 7 pounds per corner, if I remember correctly-
Old 08-17-2014, 10:18 PM   #42
Perpetuus
Data Encryption
Perpetuus's Avatar
Finished off the B6 passat aluminium spindle and control arms on both sides of the car now. The difference in the way the car rides over the road is amazing. Potholes are no longer harsh. In most cases, most potholes are simply smoothed out, and the car is less disturbed by the road surface. Interestingly, it also feels like the car has less feedback because less of the road can be read through the steering wheel. The OEM rubber bushings in the control arm are not super smooth, and has quite some resistance to get them moving. It would be nice to get lower friction bushings to improve the ride quality even more.
I can't test it any more now, because the steering wheel is now crooked to the right by 45 degrees. Alignment is needed ASAP.
Old 08-18-2014, 12:40 PM   #43
SuperSkyline89
Das Schiesse
SuperSkyline89's Avatar
Drives: 2008 CW GTI
What BBK are you planning to run?
I went StopTech up front and it cut 1 pound per rotor and 6 pounds per caliper.
2008 GTI Build Thread
Volk Racing | StopTech | HPA Motorsports
KW Suspensions | Whiteline | Integrated Engineering
SuperSkyline89 is offline   Reply With Quote
Old 08-18-2014, 01:07 PM   #44
Perpetuus
Data Encryption
Perpetuus's Avatar
Also Stoptech, with 328mm two piece rotors
Are you running two piece rotors?
