CTS Turbo
Old 12-06-2018, 09:37 PM   #2377
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
Finished getting the connector on the ECM side wiring. Still need to add Aux injectors, alternator and other wiring that doesn’t go to the ECM 60 pin connector.
Also figured out why i could only put male terminals into both ends of my connector...they were both the receptacle style instead of the plug style even though they fit together. The correct connector is on the bottom, it has a protruding end that houses female terminals. The only difference in the part number is one letter, ordered the wrong one a long while back
eurocars is offline   Reply With Quote
Old 12-06-2018, 09:41 PM   #2378
avenali312
Formula 5000 Driver
avenali312's Avatar
Drives: 2015 GTI
Man, I don't miss working with those plugs haha. Biggest one I've seen had 128 pins.
Sent from my Pixel 2 using Tapatalk
Originally Posted by merkeyterkey View Post
So today I just walked right into Mordor.
I don't have pictures or directions, it was pretty neat though.
avenali312 is offline   Reply With Quote
Old 12-07-2018, 12:08 PM   #2379
bon qui qui
Formula 3000 Driver
bon qui qui's Avatar
Drives: '06 GTI / '17 Taco
Damn, kinda an expensive mistake to make lol
mod list
bon qui qui is offline   Reply With Quote
Old 12-07-2018, 04:01 PM   #2380
eurocars
eurocars's Avatar
Drives: GTI
Only about $60, got it used from a used aircraft part wholesaler on ebay
Old 01-06-2019, 11:20 PM   #2381
eurocars
eurocars's Avatar
Drives: GTI
Picked up brass shift fork pads to go with my steel shift forks and a 4th gear support. Havenít been working on the car much because Iíve been finishing up building a photography studio for the wife in our backyard
Old 01-07-2019, 12:34 AM   #2382
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Good to hear that you still moding your car :)
Mostic is offline   Reply With Quote
Old 01-09-2019, 06:18 PM   #2383
eurocars
eurocars's Avatar
Drives: GTI
Installed the input shaft support today, was sketchy drilling a hole into the case
Old 01-16-2019, 01:14 PM   #2384
eurocars
eurocars's Avatar
Drives: GTI
Ordered some 4140 to machine for the input shaft. The rear of the shaft is hollow from the factory, going to have it machined with a slight interference to press and weld in. Hopefully with the case brace and billet insert I can keep 4th gear alive for a while
Old 01-16-2019, 02:53 PM   #2385
bon qui qui
Formula 3000 Driver
Maybe one day you'll even drive it again
mod list
Old 01-16-2019, 03:22 PM   #2386
eurocars
eurocars's Avatar
Drives: GTI
Perpetual build
Old 01-16-2019, 03:55 PM   #2387
eurocars
eurocars's Avatar
Drives: GTI
Perpetual build
Old 01-16-2019, 06:16 PM   #2388
projectDIY
Drives: Golf Mk5 Gti
Originally Posted by eurocars View Post
Perpetual build
2 years of my life waiting for every update with excitement..........
Whilst you are rebuilding and reinforcing the gearbox there's a few other parts you might want to consider such as gearbox reinforcement plate and the 5/6th gear selector fork reinforcement kit.
https://www.darksidedevelopments.co....ent-plate.html
"][/url]
projectDIY is offline   Reply With Quote
Old 01-17-2019, 03:40 PM   #2389
eurocars
eurocars's Avatar
Drives: GTI
"][/url]
Unfortunately, the case reinforcement wont work on the 02Q (MKV) as it has a steel and rubber plug vs solid aluminum on the 02M (MK4)
Also dont need the 5-6 reinforcement because I have a full steel 5-6 fork already
Old 01-19-2019, 06:18 PM   #2390
eurocars
eurocars's Avatar
Drives: GTI
Bought an 08 Passat wagon for $400 off craigslist. Pretty clean overall, needs front fenders (rust), valves/belt, cam, HPFP and valve body. Kbb is just under 5k running
Old 01-19-2019, 06:21 PM   #2391
eurocars
eurocars's Avatar
Drives: GTI
Got the head pulled off the Passat in about 4 hours this afternoon. Looks like one of the roller bearings for the timing belt failed and trashed it. The front crank seal cover is damaged and needs replaced, only 6 exhaust valves and 2 intake valves were bent in the process. Valves barely touched the pistons so theyíre still in good shape. Hope to start reassembling by next weekend
Old 01-22-2019, 10:59 AM   #2392
clockwise33
New York Giants Fanatic
clockwise33's Avatar
Drives: 2006 GTI 6MT Pkg2
Did you pull the turbo off with the head? I'm slowly preparing to do drop in rods and it seems like the easiest way to get the head off is disconnecting the turbo/manifold and leaving it chilling behind the motor. Any downside to doing it this way?
K04+APR+BillyBoat+Eurojet+Eibach+BBS+IE HPFP+SRE Clutch+JL-W7
clockwise33 is offline   Reply With Quote
Old 01-22-2019, 11:25 AM   #2393
Joshohol
FIA GT Champion
Drives: 07 Candy White Gti
Id pull the whole turbo off. Not worth having it in the way, plus it would be easier
Joshohol is offline   Reply With Quote
Old 01-22-2019, 11:39 AM   #2394
eurocars
eurocars's Avatar
Drives: GTI
I left the turbo on the head and used an engine hoist to yank it all out as one. Benefit is that you dont have to undo the lower engine mount to pull the engine forward to clear the firewall and nuts on the manifold are much easier to reach once out of the bay. In your case, you wouldnt even have to remove the turbo once the head is off. Saved you some gaskets and frustration
Old 01-22-2019, 10:46 PM   #2395
eurocars
eurocars's Avatar
Drives: GTI
Continuing the bulletproofing of the Passat. Replacing the thermostat and oil filter housing gaskets and also did the poor mans balance shaft delete since i already had to pull the pan and front oil seal cover. Engine is basically a bare block in frame now waiting for a full refresh. If anyone wants to donate some drop-in rods i’ll put them to good use
Old 01-23-2019, 10:13 AM   #2396
clockwise33
Continuing the bulletproofing of the Passat. Replacing the thermostat and oil filter housing gaskets and also did the poor mans balance shaft delete since i already had to pull the pan and front oil seal cover. Engine is basically a bare block in frame now waiting for a full refresh. If anyone wants to donate some drop-in rods iíll put them to good use
I'm kicking around the idea of cutting the balance shaft gear while I'm doing drop in rods, as I plan on tracking this car eventually when my sons are old enough to ride along. Is the increase vibration really that bad? I have a civic beater with a 1.7 4cyl and no balance shafts and there really isn't that much buzzing.
What really got me thinking about it is the new Honda 2.0T. For the Accord, Honda has balance shafts integrated into the oil pump very similar to the FSI design, but they are deleted in the Civic Type R for better track reliability.
Old 01-23-2019, 12:24 PM   #2397
eurocars
eurocars's Avatar
Drives: GTI
From what I’ve been told, on stock style mounts it isn’t very noticeable. On my GTI with poly/Delrin, it’s veeeerrrrrry noticeable but i don’t mind it
Old 01-23-2019, 12:27 PM   #2398
eurocars
eurocars's Avatar
Drives: GTI
Picked up the input shaft from the machine shop and had the new insert pressed in. Going to tack weld the end of it and thinking about fabbing up a pilot bearing extension for the splined end of the shaft to really make sure it won’t go anywhere
