Parts4Euro
Old 09-22-2019, 01:32 PM   #2443
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
AEM 340 pump is dead on arrival. It runs for 5 seconds then barely pushes a tiny stream of fuel. AEM only has a one year warranty and i bought it a year and a half ago but just tried it out. Any suggestions for other LPFPs? I bought that one because it was E85 compatible
eurocars is offline   Reply With Quote
Old 09-23-2019, 10:14 PM   #2444
eurocars
eurocars's Avatar
Drives: GTI
Got the new dogbone mount installed tonight (old BSH is for sale in the classifieds if interested). Probably more NVH especially with the VWR puck.
Ordered a 42DD shift cable bracket to try and support the cables and keep them off the exhaust. 42DD said it would fit with the OEM metal cable bracket but it’s way off
Also started on the alignment since it has a TT rack. Used whatever i could find to lock the wheel
Old 09-24-2019, 12:08 PM   #2445
bon qui qui
Formula 3000 Driver
bon qui qui's Avatar
Drives: '06 GTI / '17 Taco
I put a VWR puck in my car too. That APR dog bone does look pretty nice.
CMP, VIR, AMP, Watkins Glen, Daytona, NCM, Road Atlanta, Barber, NJMP, Summit Point
bon qui qui is offline   Reply With Quote
Old 09-24-2019, 12:48 PM   #2446
eurocars
eurocars's Avatar
Drives: GTI
I bought it because of the spherical bushing. I wanted some articulation in the mount, whereas the BSH one didnt have enough due to the design. BSH would have probably been fine if the dogbone and subframe bushings were still softer rubber/poly but I didnt want to risk cracking the case under hard acceleration/launches
Old 09-26-2019, 02:20 PM   #2447
clownish
just clowning around
clownish's Avatar
Drives: Mk5 R32
Did you consider the 034 mount?
clownish is offline   Reply With Quote
Old 09-26-2019, 03:03 PM   #2448
eurocars
eurocars's Avatar
Drives: GTI
APR wasnít much more, it came with ARP bolts instead of regular grade 8 and i thought it looked better
Old 10-02-2019, 09:27 PM   #2449
eurocars
eurocars's Avatar
Drives: GTI
AEM pump wasn’t dead, it was pumping fuel out of the basket faster than it could fill it. Drilled 6 holes and it should be much better.
TT axle on the passenger side didn’t fit at all (DSG vs 6MT). Printing an axle spacer to test fit
Old 10-03-2019, 09:27 PM   #2450
eurocars
eurocars's Avatar
Drives: GTI
Got it started tonight, fired up first try which I was amazed with. Video won’t upload with sound so I’ll get another one tomorrow
Old 10-07-2019, 10:02 AM   #2451
eurocars
eurocars's Avatar
Drives: GTI
So after i got it started and running, i noticed something wasn’t quite right. It ran decent but sounded like a Subaru. Got to troubleshooting and found out that i had swapped injector #1/2 wiring at the bulkhead connector. They were both firing, just at the wrong times. Swapped pins and runs much better now.
Had a small coolant leak at one of the turbo supply lines but that is fixed, and there is a tiny amount of oil seepage from the engine girdle plate. I ALMOST gasketed it when i pulled the oil pan to seal it but thought it would be fine. Engine will need to come out to seal it back up, but it’s such a small leak I’m going to try and put some miles on it to work out the other kinks before i pull it again
Old 10-08-2019, 10:09 AM   #2452
woofie2
woofie2's Avatar
Drives: 2011
Originally Posted by eurocars View Post
So after i got it started and running, i noticed something wasnít quite right. It ran decent but sounded like a Subaru. Got to troubleshooting and found out that i had swapped injector #1/2 wiring at the bulkhead connector. They were both firing, just at the wrong times. Swapped pins and runs much better now.
Had a small coolant leak at one of the turbo supply lines but that is fixed, and there is a tiny amount of oil seepage from the engine girdle plate. I ALMOST gasketed it when i pulled the oil pan to seal it but thought it would be fine. Engine will need to come out to seal it back up, but itís such a small leak Iím going to try and put some miles on it to work out the other kinks before i pull it again
Pictured as a black and white scene from Young Frankenstein, "Its alive, Its Alive!"
woofie2 is offline   Reply With Quote
Old 10-09-2019, 07:27 PM   #2453
eurocars
eurocars's Avatar
Drives: GTI
Finished fabbing the mount for the catch can. Trying to decide if i run the valve cover port to it as well or leave the filter on it
Old 10-10-2019, 04:40 AM   #2454
Bluepower
Drives: Vw Corrado 1.8 20vt big turbo
Open filter will cause bad smells and oil vapour residu in your engine bay.. I would reroute it to somewhere under the car, or back into the intake
Bluepower is offline   Reply With Quote
Old 10-10-2019, 08:44 AM   #2455
eurocars
eurocars's Avatar
Drives: GTI
That was already considered, there is no other place outside of the bay to relocate it
