Old 08-21-2019, 06:11 PM   #1
sumofish
Drives: 2009 4door GTI
AC not working
My AC seems to be blowing hot air.
I check both fans are working, I can hear a humming noise coming from the engine when the AC is on and it goes away when I turn it off. Also there seems to be a small squeaking noise when the AC is on.
Is the AC compressor not working anymore?
sumofish is offline   Reply With Quote
Old 08-23-2019, 01:30 PM   #2
iKhmaiFoSho
Drives: 2006 Audi A3 2.0T FSI
I've had this issue so I plugged in a vag com to monitor the refrigerant pressure and state of the a/c. I notice I was high on a/c refrigerant and the a/c was turning off and on, so I "safely" purged out some refrigerant to keep it below the threshold and bingo. I believe this is a safety feature so we don't over pressure the a/c compressor and damage it, pretty cool. Try this first.
If all checks out and you are below the refrigerant then maybe it can be the compressor.
iKhmaiFoSho is offline   Reply With Quote
Old 08-24-2019, 05:29 PM   #3
sumofish
How do I "safely" purge out some of the refrigerant?
Old 08-25-2019, 04:02 AM   #4
vwengineer
FIA World Rally Car Newbie
vwengineer's Avatar
Drives: Golf 5 GTI (stock AXX)
You don't, go to a shop, get the system evacuated and refilled with the correct amount of refrigerant. That would be step one, step two would be to replace the actuator on the A/C compressor that is prone to failure.
vwengineer is offline   Reply With Quote
Old 08-25-2019, 06:28 PM   #5
sumofish
Is it hard to replace the actuator?
Old 08-26-2019, 02:33 AM   #6
vwengineer
vwengineer's Avatar
It's not so hard but you have to evacuate the system
