Old 07-18-2018, 11:48 PM   #2333
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
TT rack swapped in, end links built, harness almost ready for the amphenol connector
eurocars is online now   Reply With Quote
Old 07-20-2018, 07:11 PM   #2334
wndwsdwngti860
Upsidedown
wndwsdwngti860's Avatar
Drives: '08.5 GTI BMP TSI
upside to the TT rack vs gti?
wndwsdwngti860 is offline   Reply With Quote
Old 07-20-2018, 09:00 PM   #2335
eurocars
eurocars's Avatar
Drives: GTI
It fits TT spindles, GTI doesnt plus tighter ratio (14.6 vs 15.6)
Old 07-22-2018, 05:18 PM   #2336
eurocars
eurocars's Avatar
Drives: GTI
New wastegate dump tube fabbed and wrapped. Downpipe mounting bracket fabbed and welded
Old 07-22-2018, 05:36 PM   #2337
Joshohol
FIA GT Champion
Drives: 07 Candy White Gti
Looking good
Joshohol is offline   Reply With Quote
Old 07-22-2018, 08:47 PM   #2338
CursedCamfollower
Drives: MKV 4-door CW GTI
Thought the TT rack was 16.9? I know some guys have milled down the rack though
CursedCamfollower is offline   Reply With Quote
Old 07-22-2018, 09:32 PM   #2339
eurocars
eurocars's Avatar
Drives: GTI
http://www.audi-eg.com/content/dam/n..._Coupe_2_0.pdf
Old 07-29-2018, 03:34 AM   #2340
CursedCamfollower
The date on that document suggests that it is for the new mk3 TT based on MQB architecture(EUrope got the mk3 TT in 2014) and not the PQ35 architecture that the mk2 TT/MK5/MK6 chassis is based on which again makes me question if the mk2 TT rack is faster than a GTI rack. The improved roll center should be nice though. Are you getting new axles seeing as the track width is now wider?
Old 07-30-2018, 09:22 AM   #2341
eurocars
eurocars's Avatar
Drives: GTI
Could be the MK3, that was the only technical spec doc i could find. Doubt the steering would change between MK2/3 though.
Will be eventually be picking up TT axles, using MKVs to get it moving for now
Old 08-10-2018, 07:28 PM   #2342
eurocars
eurocars's Avatar
Drives: GTI
Sensor wiring run through the pass through. Have gauge sensors (EGT, fuel pressure, oil pressure) and all oxygen sensor wiring (primary, secondary, AEM) running through it. Had to make new extension harnesses for the primary and secondary oxygen sensors to be able to run inside the car. Will probably shield the wiring even though having the wastegate dump wrapped should be enough protection. Made a small aluminum bracket for the rear sensor plugs. Steering rack wiring is in the corrugated loom
Old 08-13-2018, 08:59 AM   #2343
xSabretoothx
Fast w/ training wheels
xSabretoothx's Avatar
Drives: Better Than You
Looking good! This might actually be on the road one day.
"You can never get enough of the things you don't need, because the things you don't need can never satisfy."
Marvin J. Ashton
xSabretoothx is offline   Reply With Quote
Old 08-13-2018, 01:14 PM   #2344
Das Gespenst
Formula 3000 Champion
Das Gespenst's Avatar
Damn man, project is coming along!! Looking great brother! One of these days when the grey car gets swapped over to dedicated track duty as well, I want to pull the white one completely apart and just clean up/make everything shiny new again.
Old 08-15-2018, 02:37 PM   #2345
eurocars
eurocars's Avatar
Drives: GTI
Tapped and plugged the oil feed hole for the vacuum pump in the HPFP housing. Since i deleted the vacuum pump, the hole needs plugged or the chain tensioner and N205 will not have enough oil pressure to operate correctly. Used an 8-32 threaded insert
Old 08-16-2018, 12:52 PM   #2346
bon qui qui
Formula 3000 Driver
bon qui qui's Avatar
Drives: '06 GTI / '17 Taco
I just welded mine shut.
mod list
bon qui qui is offline   Reply With Quote
Old 08-16-2018, 03:53 PM   #2347
eurocars
eurocars's Avatar
Drives: GTI
I wanted something a little less permanent. I did loctite it in though and the allen key to install/remove is pretty small and wimpy. I have a couple spares if it wont come out
