Old 04-24-2017, 12:48 AM   #1
RalleyTuned
RalleyTuned's Avatar
Drives: 07 Audi A3
Cheap and Easy Suspension Upgrades!
Made a couple quick and easy upgrades to my car last week. I was having an issue on the highway of the car dancing side to side on uneven or graded. I noticed it this winter, but attributed it to snow tires and poor roads. Once I swithed back to my summer wheels, it got worse!
My car has over 200K on the chassis so the rubber bushings are pretty worn. The worst culprit in these care is always the front control arm bushing on the rear of the arm. I upgraded to the Meyle HD bushings, I didn't want to add any more road noise up front as I already have plenty with my Ground Control camber plates, so I wanted to stick with rubber, but get the best one I could get. The new bushings set cost about $150 online.
Next up was one of the other major contributors to suspension movement in this car, the trailing arm bushings. Stock, these are very soft, tack on 200,000mi and they are toast! When I popped out the trailing arms, I could wiggle the bushing with almost no force, and it moved probably 1/2" or more with ease! For this bushing, I chose the Super Pro trailing arm bushing kit (~$75). Installation on these was super easy with a press, and in under and hour I had the trailing arms re-installed.
Overall the upgrading of the new bushings was a fantastic upgrade. The front control arm bushings increased the steering response greatly, the car does not feel mushy in the front end anymore. Steering response is crisp and predictable, and the car tracks very well when settled into a corner. On the rear end, the first thing I noticed was a increase in ride quality. The new bushings allow completely free movement of the trailing arms and greatly softened the feel of the rear suspension over larger bumps. The rear of the car feels much more settled in corners as well. I am also happy to report the dancing issues I was having have been greatly reduced. I am going to be replacing the tie rod ends and ball joints soon also, hoping to completely eliminate the issue.
Performance Technician- Alignment Specialist
RalleyTuned.com - NW Motorsports Inspired Automotive Blog
Achtuning.com - European Performance Shop
DemonRally.com PNW Premier VW Rally Team
RalleyTuned is offline   Reply With Quote
Old 04-26-2017, 02:05 PM   #2
Simmsled
Parking Garage > Tree
Simmsled's Avatar
Drives: my wife crazy
Nice.
DRIVE_
Simmsled is offline   Reply With Quote
Old 06-27-2017, 02:28 PM   #3
Brigand
Newbie
Brigand's Avatar
Drives: 2006 MKV GTI
Does anyone have a source for the front LCA rear position bushings or know of an equivalent part?
I'm not convinced that poly is the best material for suspension bushings, especially for the front LCA / rear position.
My 2006 GTI is starting to show its age in various areas, and bushings are one of them .
Brigand is offline   Reply With Quote
Old 06-29-2017, 12:16 AM   #4
somerset9
Drives: 2007 UG GTI
I would go with Febi 33973. They are the S3/TT-RS ones. They don't add any caster or anti-lift properties, but they are solid, i.e. no holes like the stock ones.
https://www.eeuroparts.com/Parts/776...g-Front-33973/
somerset9 is offline   Reply With Quote
Old 06-29-2017, 01:41 AM   #5
Brigand
Newbie
Brigand's Avatar
Awesome, thanks for the link. And look at that price, that's awesome.
Old 06-29-2017, 04:32 PM   #6
BudgetPhoenix
Touring Car Newbie
Drives: 09 GLI DSG
Anyone with a DSG have any tips for removing the driver side control arm bushing. Cant remove the control arm without dropping the subframe. Or can you do it by undoing the engine and trans mount and jacking the up the engine?
BudgetPhoenix is offline   Reply With Quote
Old 06-29-2017, 05:24 PM   #7
LilRaverBoi
Optometrist Prime
LilRaverBoi's Avatar
Drives: 2009 CW GTI, 1997 CW Golf
People sometimes omit these sorts of upgrades instead spending money on 'performance' mods. The truth is that a good firm/predictable suspension will do about as much for your car on the street or track than performance stuff will. Being able to hit corners harder and have reliable/predictable steering input/output is paramount for spirited driving IMHO.
-'97 Candy White Golf: 2.slo, 276 cam/chip, 2.5" Borla Exhaust, Borbet type A's
-'09 CW GTI: 2.0 TSI,factory votex kit, Forge DV, Unitronic intake, lighting mods, H&R Coils, Whiteline bushings everywhere, Whiteline F/R swaybars + adj. endlinks, BSH engine/trans mounts, BillyBoat TBE
-'62 Beetle: 1600sp, slammed/rusty/sexy
LilRaverBoi is offline   Reply With Quote
Old 06-29-2017, 09:34 PM   #8
Joshohol
FIA GT Champion
Drives: 07 Candy White Gti
Originally Posted by BudgetPhoenix View Post
Anyone with a DSG have any tips for removing the driver side control arm bushing. Cant remove the control arm without dropping the subframe, or can you do it by undoing the engine and trans mount and jacking the up the engine
What? It comes off separately from the subframe?
Sent from my SM-N920P using Tapatalk
Joshohol is offline   Reply With Quote
Old 06-29-2017, 10:11 PM   #9
BudgetPhoenix
Touring Car Newbie
Drives: 09 GLI DSG
If you want to remove the entire driver side control arm instead of trying to pry off the bushing bracket while leaving the control arm on, you cant because the front control arm bolts hits the transmission on the driver side if you have a DSG. So you have to drop down the subframe, well not all the way but enough so the bolt can clear. But I was asking if anyone knows if its possible to just undo the mounts and jack the engine and trans up to make enough room to remove the bolt.
