Old 04-02-2017, 12:01 PM   #1
kakluote
FIA World Rally Car Champion
kakluote's Avatar
Drives: Audi TT 2.0t fsi
about the tune of "boost by gear"
just want to do a little fine tune of K04 file which is to lower the output in 1st gear which means less tire spins in launch ,APR K04 V3.1 just does it
Is it easy for tuners to add this feature?
APR K04, HPFP ,RFD,APR downpipe, Milktec Cat-back, HPA DSG Stg2, S3 OEM FMIC,NSP P-flo,OZ 18 Wheel
kakluote is offline   Reply With Quote
Old 04-02-2017, 12:22 PM   #2
larcic
Drives: 2008 Volkswagen GTI 2-Door Wht
dsg right? Idt this is possible on manual
UNITRONIC STAGE 2 HPFP, NEUSPEED INTAKE, EBAY DP, APR HPFP, APR FMIC, BSH CATCH CAN, DIESELGEEK SIGMA SIX SHORT SHIFTER, R8 COILPACKS, CTS B-COOL OIL FILTER HOUSING, KONI SHOCKS/STRUTS, RES DELETE, NEWSOUTH BOOST GAUGE, EURO DASH TRAY, CHROME/ROUND A/C KNOBS
larcic is offline   Reply With Quote
Old 04-02-2017, 01:06 PM   #3
kakluote
kakluote's Avatar
to be more accurate
"torque limited" only on 1st gear
Old 04-02-2017, 01:18 PM   #4
kakluote
kakluote's Avatar
this:
While the end goal is similar, APR’s torque management system differs greatly from archaic “boost-by-gear” strategies. “Boost-by-gear” strategies rely on a static limitation of boost in an effort to minimize wheel spin, but to work properly they must be dialed in for every situation. The same boost levels in different weather conditions, such as a hot summer day and a cold winter month, can produce vastly different torque levels. Since APR’s torque management system relies on the engine management’s phenomenal torque reporting abilities, it is able to adjust to every environmental situation it encounters. To achieve a targeted torque level, the ECU applies the appropriate changes to mass airflow and ignition.
Old 04-03-2017, 02:33 PM   #5
ViRtUaLheretic
╭∩╮(︶__︶)╭∩╮ haters
ViRtUaLheretic's Avatar
Drives: 2009 VW GTI & 2003 Mazda Miata
Cruizin01 got this setup on his BT MKV, check the BT FAQ2 thread:
http://www.golfmkv.com/forums/showpo...&postcount=614
http://www.golfmkv.com/forums/showth...ar#post3459929
::APR stage2,Dogbone::BSH -Intake,TB Pipe::Eurojet v1.0 TBE::Whiteline -A.L.K.
::Devils Own DVC-30::Neuspeed -Discharge::BC Racing BR coils::Unibrace -xB & uB
::OSIR::Flik FTD::245x40x17::Porsche 17Z BBK::Bildon Studs::Hawk HPS::034 RSB,Mounts[/size]
Read this for TSI INFO/FAQ
ViRtUaLheretic is offline   Reply With Quote
