Parts4Euro
Old 05-16-2010, 07:04 PM   #1
idk alex
idk alex's Avatar
Drives: Skateboard
Car wont start, then starts?
So this morning I went to start my car and it wouldnt start. The battery seemed dead, the car wouldnt lock and the interior lights didnt come on. I was supposed to go to the beach so my friends drove me. I came back to it about 7 hours later and it started. But now my steering wheel light is on. Im trying to get my friend to scan my car. I hope that nothing needs to be replaced, my car isn't exactly stock >.<
Any thoughts?
TSI and the Engine mods are
Apr Stage 2
custom intake
dp
tiguan pipe
motor mounts
short shifter
I think thats it, I dont really remember.
Thank you
FS: PART OUT
idk alex is offline   Reply With Quote
Old 05-16-2010, 07:19 PM   #2
The Fed
Old Guys Rule
Drives: 2007 GTI DSG APR S1
Could be a number of things. Try looking at the battery terminals. Is there any corrosion under a terminal or is a terminal loose? You can try using a voltmeter to see if the battery's good. Steeering wheel icon is related to the immobilizer but I believe a low battery will light it as well.
Old 05-16-2010, 07:38 PM   #3
idk alex
idk alex's Avatar
Drives: Skateboard
I checked my battery and everything looks fine.
FS: PART OUT
Old 05-16-2010, 11:35 PM   #4
65dunebuugy
insert custom title here
65dunebuugy's Avatar
Drives: 06 CW GTI, 01 Jetta Wolfsburg
drive it and the steering wheel light will go off
65dunebuugy is offline   Reply With Quote
Old 05-17-2010, 09:54 AM   #5
idk alex
idk alex's Avatar
Drives: Skateboard
Well usually maybe 1 out of 10 drives my steering wheel light came on and after ten seconds or so it went off. This one was on for a couple minutes until i shut the car off.
FS: PART OUT
Old 05-17-2010, 09:58 AM   #6
Mataleao9380
Rally Car Champion
Drives: MKV GTI 07
If your windows need to "re-learn" the auto-up and auto-down function--it sounds like your battery "died" or just barely alive. This in conjunction with the steering wheel light--sounds a lot like what would happen if you disconnected your battery.
Did you also have to switch back to Stage 2?
Mataleao9380 is offline   Reply With Quote
Old 05-17-2010, 11:09 AM   #7
idk alex
idk alex's Avatar
Drives: Skateboard
I havent driven it actually, but since about september. MY car has done weird things. Sometimes it wont have auto up and down windows. Sometimes one side will have it. Sometimes none, and sometimes they have randomly gone up or down. Im thinking i need a new battery :/
FS: PART OUT
Old 05-17-2010, 01:21 PM   #8
idk alex
idk alex's Avatar
Drives: Skateboard
Just rememered that, it would reset the trip randomly. It has probably restarted itself 7 times in the past 2 weeks
FS: PART OUT
Old 05-17-2010, 03:21 PM   #9
HereticByDefault
Formula 3000 Driver
HereticByDefault's Avatar
Drives: too high
That all sounds like behavior after the battery has been disconnected. If the auto up/down thing happens again, whatever window it's affecting, Just roll it down a little bit, roll it back up and hold it in the up position for a couple seconds. The auto function should work after that
It seems a little weird to me that sometimes it only happened on one window and not the other, but replacing the battery would probably be your best bet right now.
HereticByDefault is offline   Reply With Quote
Old 05-17-2010, 06:09 PM   #10
idk alex
idk alex's Avatar
Drives: Skateboard
Today while driving, the steering wheel light went off. But the auto up and down thing was a pita.
At first neither had it, then passenger side had it. Then neither had it. Jebus
FS: PART OUT
Old 05-17-2010, 06:16 PM   #11
Chris@RT
Drives: a3
To reset the auto up you have to do each window at a time lower it about 6" bring it allt he way up, lower 6" or so bring it up.. do each window one at a time you can't do multiple windows until that is reset
if you lost it again then that would mean the battery probably lost power again.
Chris@RT is offline   Reply With Quote
Old 05-17-2010, 06:26 PM   #12
idk alex
idk alex's Avatar
Drives: Skateboard
Well, judging that my trip has magically reset by itself recently, im guessing its my battery
FS: PART OUT
Old 05-26-2010, 07:42 PM   #13
Stage2Sasquatch
Drives: 2007 VW GTI
Hmmmm, The same exact thing happened to me today alex. Although my trip computer is fine..
Stage2Sasquatch is offline   Reply With Quote
Old 06-27-2010, 09:38 PM   #14
projekt.kieru
Inspired.
projekt.kieru's Avatar
Drives: Efficiently
i am also TSI - what is the immobilizer active?
Golden State.
projekt.kieru is offline   Reply With Quote
Old 06-28-2010, 01:23 AM   #15
idk alex
idk alex's Avatar
Drives: Skateboard
my car has been running like a champ since this happened. Gotta love german electronics
FS: PART OUT
Old 06-28-2010, 02:05 AM   #16
projekt.kieru
Inspired.
Drives: Efficiently
how did you fix it?
Golden State.
Old 12-19-2013, 09:25 AM   #17
bushtucker
Drives: '06 BMP GTI
probably changed out the negative battery cable and all other grounding cables.
bushtucker is offline   Reply With Quote
Old 12-19-2013, 09:36 AM   #18
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
probably didnt
eurocars is offline   Reply With Quote
Old 12-19-2013, 10:10 AM   #19
Duster117
FIA GT Newbie
Drives: 07 GTI
Had this problem right after I got my gti. Most likely one of the battery terminals are loose. Mine was just barely loose. Couldn't tell by just looking at them.
BSH intake|BSH pcv block off/race catch can|BSH relocated dv|Magnaflow cat back/downpipe|GIAC
I will most likely never see a supercar in person, much less own one.
Originally Posted by kdisjubjub View Post
What are you talking about, you own a supercar.
Duster117 is offline   Reply With Quote
Old 12-19-2013, 01:55 PM   #20
HereticByDefault
Formula 3000 Driver
Drives: too high
Anyone who is having this problem, clean the positive and negative terminals and leads. Then tighten them a bit to make sure theres full contact.
If you can move them around at all, tighten more until you cant.
Sent from my SGH-T989 using Tapatalk 2
Old 12-19-2013, 02:17 PM   #21
Duster117
FIA GT Newbie
Drives: 07 GTI
^^THIS!!!!
Old 12-25-2013, 01:21 AM   #22
idk alex
idk alex's Avatar
Drives: Skateboard
FS: PART OUT
