Parts4Euro
Old 11-11-2015, 10:31 AM   #23
xSabretoothx
Fast w/ training wheels
xSabretoothx's Avatar
Drives: Better Than You
Skid plates are for pansies!!
"You can never get enough of the things you don't need, because the things you don't need can never satisfy."
Marvin J. Ashton
xSabretoothx is offline   Reply With Quote
Old 11-11-2015, 10:41 AM   #24
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
If you have the same roads we have here then the skid plate will be in your priorities!
Philosophy Of Eagles: Eagles flies only with eagles!
Mostic is offline   Reply With Quote
Old 12-25-2015, 04:24 AM   #25
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
few updates
I was very busy last weeks and I had no time to update the thread and continue the story.
Few parts have been arrived from USP Motorsports.
  • Ferrea 2.0T FSI Valvetrain Kit- Stock Sized Valves
  • Valve Stem Seal Kit FSI/TSI
  • IE Valve Guide: 2.0T FSI Engines
  • Intake Camshaft: 2.0T FSI (06F109101J)
  • Exhaust Camshaft (06F109102E)
  • Cam Follower (Hydraulic Lifter)
  • Cylinder Head Gasket Set - VW/Audi 2.0T FSI
  • ARP Camshaft Girdle Bolt Kit: 2.0T FSI
  • ARP VW/Audi 2.0L (FSI) 4cyl Cam Tower Bolt Kit
  • IE 2.0T FSI Catch Can Kit (Requires IE Valve Cover)
  • IE 2.0T FSI Billet Valve Cover-ROW (IEBAVC5)
  • Valve Cover Gasket 2.0T FSI (06F103483D)
  • IE Rear Breather Blockoff Plate For Transverse 2.0T FSI/TSI Engines (IEBAVC8)
  • IE Evap Crossover Tube Relocation - 2.0T FSI (IEBAVC11)
  • EZ Oil Drain Valve Kit (EZ-106KT)
  • Oil and coolant lines and fittings (latest revision)
  • Calico Coated Rod Bearing Set for 4 Cylinder VW/Audi
  • Calico Coated Main Bearing Set - Audi/VW 4 Cylinder
  • Forge Turbo Hose Kit 2.0T FSI- Red
  • Forge Silicone Coolant Hose Kit 2.0TFSI- Red
I cancelled the IE Ultimate Crankshaft Girdle Kit as it will take few weeks to be ready.
Also, I got one item of my 2016 plan, I got 2011 Scirocco White/Black 1.4 TSI. I will install/swap another 2.0T FSI system on it (still looking for one), and after doing a full swap and make sure everything is working perfectly, I will install the upgrades I have in my Black MKV in the White Scirocco.
It is headache but let's see how it will end up!
more is coming
Old 12-26-2015, 12:54 PM   #26
Das Gespenst
Formula 3000 Champion
Das Gespenst's Avatar
So wait..... you're dropping the GTI and swapping everything into a Scirocco????? I want one soooooo oooooo bad! This is going to be interesting!
Old 12-26-2015, 01:49 PM   #27
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Yeah it is really interesting it was my dream since I got my MKV, I used the MKV as a demo and test before I plan for the Scirocco.
I am looking for another 2.0T FSI system in order to install it on the Rocco and make sure everything will function well then I will swap the performance parts/stuff from the MKV to it.
I am totally supporting you, Go for the Scirocco
Old 12-26-2015, 10:17 PM   #28
LilRaverBoi
Optometrist Prime
LilRaverBoi's Avatar
Drives: 2009 CW GTI, 1997 CW Golf
New-style Sciroccos are not available here in the US :( You'd have to import from Canada or Europe....at least I think Canada got them.
-'97 Candy White Golf: 2.slo, 276 cam/chip, 2.5" Borla Exhaust, Borbet type A's
-'09 CW GTI: 2.0 TSI,factory votex kit, Forge DV, Unitronic intake, lighting mods, H&R Coils, Whiteline bushings everywhere, Whiteline F/R swaybars + adj. endlinks, BSH engine/trans mounts, BillyBoat TBE
-'62 Beetle: 1600sp, slammed/rusty/sexy
LilRaverBoi is offline   Reply With Quote
Old 12-26-2015, 11:10 PM   #29
SuperSkyline89
Das Schiesse
SuperSkyline89's Avatar
Drives: 2008 CW GTI
We don't get them either, although HPA Motorsports will sell you one for $150,000 with like 600hp
http://www.hpamotorsports.com/scirocco.html
2008 GTI Build Thread
Volk Racing | StopTech | HPA Motorsports
KW Suspensions | Whiteline | Integrated Engineering
SuperSkyline89 is offline   Reply With Quote
Old 01-08-2016, 07:56 AM   #30
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
It is not common in my country too but you can get it.
This one for $150,000 is fully loaded and modified up to stage 5++
It is a bit expensive but I would go for it if I have that much money!
Old 01-08-2016, 07:58 AM   #31
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Question Need your advise about JE Pistons 8.5:1 or 9.5:1
Hi Guys,
I am confused between the JE Pistons 8.5:1 or 9.5:1 for the 2.0T FSI engine. I am already running the JE 9.5:1 in my setup with GTX2867R but I am preparing another engine for another car and I will use GTX2867R kit for a while then I will replace it by EFR7163 kit.
Target:
Like all of us (crazy people) to run an aggressive setup/tune with maximum power the car can get with 0 timing pull
Note:
The fueling here is VERY bad, the octane 95 we have here which is equal to RON98 is like octane 91 = RON93.
I will run the octane 95 we have here with WMI 50/50
What is your opinion/advise?
http://www.golfmkv.com/forums/showth...05#post3797505
Old 01-12-2016, 08:25 AM   #32
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Scirocco Project
I will jump the GTX2867R and engine modifications journey because I will repeat it in the coming one!
I was looking for a Rocco to swap to it, I bought a used 2011 Scirocco White/Black 1.4TSI, the engine of it is damaged and it was parked for a while in the agency warehouse, so it looks like what I am looking for.
some pic from the previous owner gallery
and here without engine
then we cleaned the engine bay and the installation process started
more is coming
Old 01-12-2016, 08:36 AM   #33
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
ME & MY MKV Build! (Fun, Tough & Cost)
So, after the engine installation went successfully we moved to the interior!
I have some requests to have it in the car.
Dynaudio, OEM front parking sensor, 220 power output socket, tire pressure switch, etc...
The interior installation went successfully yesterday but I don't have pics of it yet.
The car will move today/tomorrow for painting, I will go for "Oryx - Weiss with Pearl Effect (L0K1)" which the color I really love it.
The paining process is expected to take around 15 days, and after that I will drive the car for a while then the engine modifications and some parts movement from the MKV to the Rocco will start
Wish me luck because I think I will need it and more than that too!
more is coming
Old 01-12-2016, 10:56 AM   #34
LilRaverBoi
Optometrist Prime
Coming along nicely! Looks like the Scirocco shell was just what you wanted and a great place to start.
Old 01-12-2016, 11:08 AM   #35
xSabretoothx
I love this kind of project. What kind of weight difference are you looking at here?
Marvin J. Ashton
Old 01-12-2016, 01:39 PM   #36
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
It was my plan from the beginning, I did all what I did in the MKV to be ready for the Rocco.
Old 01-12-2016, 01:41 PM   #37
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
I am not targeting a specific weight.
The MKV curb weight is between 1,323 kg (2,917 lb) to 1,617 kg (3,565 lb) while the Scirocco Curb weight is 1,298 kg (2,862 lb), so the Rocco is lighter by 25kg or more, I can say 120kg in average.
Also, in the Rocco I will try to move the best from the MKV and install new stuff if it is really better and worth!
Old 01-12-2016, 02:52 PM   #38
alfmoonspace
Touring Car Newbie
alfmoonspace's Avatar
Drives: 2007 5DR GTI K04?
You going to sell the MKV afterwords?
alfmoonspace is offline   Reply With Quote
Old 01-12-2016, 03:00 PM   #39
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Yeah, I will sell it MKV GTI stock with few exterior modifications
- Eagles flies only with eagles!
- To reach the top you must fly with the Top!
Old 01-17-2016, 07:11 AM   #40
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Here are quick photos I received from my friend who is take caring of the painting process
more is coming
Old 01-23-2016, 05:15 AM   #41
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Painting update
Here are pics from the painting process;
The roof still pending and I am not expecting to complete the process before 2 weeks!
I found that the front pumper must be replaced as there are lots of cracks inside it, and I don't wanna go for the R style as I like having fog lights & DRL not only DRL.
I want to go for Scirocco rear diffuser conversion to r style, but I couldn't find yet a rubber one on the internet.
more is coming
Old 01-23-2016, 07:20 PM   #42
alfmoonspace
Touring Car Newbie
What color are you going with?
Old 01-24-2016, 12:32 AM   #43
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Old 01-24-2016, 01:22 PM   #44
high_octane3541
Formula 5000 Driver
high_octane3541's Avatar
Drives: 08 MkV GTI / 2016 S3
Just out of curiosity, how much to paint the car?
Trying to decide if I should get a re-spray or just get it wrapped
B00ST!!!
IG: high_octane3541
high_octane3541 is offline   Reply With Quote
