Old 01-12-2019, 02:22 PM   #243
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Hello,
Do you know how to weld the fuel tank?
It’s for my Scirocco project.
Mostic is offline   Reply With Quote
Old 02-16-2019, 04:21 PM   #244
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Okay, here are few updates;
I started to work on the Quattro project...
Preparing for the AWD.
Open the second hole for the tank.
Covering the welding.
Close to finish.
Haldex installed and coded
Then as all projects you should have a problem that complicate it
ABS error;
I checked similar project who had the same issue, but he changed the cluster from Scirocco and replaced by Golf R one.
Here is his comment
“However, the conversation gradually drew the attention to the fact that the ABS control device is so "crooked" that it listens the vehicle model / type code sent from the CAN bus to the instrument panel and does not encode the conflicting type code itself. That is, when the instrument panel claims a car to Scirocco, the ABS control device does not allow it to encode itself to Golf. And Scirocco can't be a four-wheel drive. On the instrument panel, that type is "hard-coded", but it cannot be changed by VCDS.”
I believe if the Scirocco instrument cluster changed from FWD to AWD then the ABS fault will disappear. I don’t know how yet but hopefully will figure it out, all support are more than welcome :)
Stay tuned, more is coming
Old 02-18-2019, 10:45 AM   #245
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Here is the AWD video.
https://vimeo.com/317987684
Old 02-18-2019, 12:27 PM   #246
GIACUser
Master Wallet Mechanic
GIACUser's Avatar
Drives: 2008 UG EFR7163
Congratulations! So jealous, that you have Scirocco and now an AWD. I would much rather have that body style.
2008 GTI EFR7163
Old 02-18-2019, 04:28 PM   #247
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Thanks! I like the Scirocco style so much that’s why I insisted to have the AWD on it instead of the MK6 while it was gonna be easier with the MK6
Old 02-18-2019, 04:31 PM   #248
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Mission accomplished!
Just few modifications in the suspension and bushing then I can drive it. Unfortunately, it will be with the K04 turbo instead of the BT for the time being but at least a serious step is achieved.
Old 02-26-2019, 06:43 PM   #249
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Quick updates;
New Ultra Racing Bars
And 3D cluster
More is coming very soon
Old 03-01-2019, 11:45 PM   #250
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
3D cluster is working fine
Old 04-13-2019, 11:27 AM   #251
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Changed the VMR wheels today to the Audi 19” one.
I like the VMR more
Most probably I will paint the Audi wheels maybe I will accept it!
Old 04-13-2019, 01:12 PM   #252
GIACUser
GIACUser's Avatar
Love that body style, sooo jealous. New wheels look great.
2008 GTI EFR7163
Old 04-13-2019, 01:17 PM   #253
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
Thanks my friend, I love it too :)
Which one looks better, 18” VMR or the 19” Audi?
And what about the 19” Audi color, is it okay? Or better to paint it another color?
I found these pics on Internet for same wheels painted to different color.
Old 04-13-2019, 03:34 PM   #254
GIACUser
GIACUser's Avatar
Each to his own on wheel color but like the look of the 19's and for me silver looks good because I like the stealthy look.
2008 GTI EFR7163
Old 06-01-2019, 10:20 AM   #255
Nitrous1024
Touring Car Champion
Drives: 2008 MK5 Golf GTI (Autobahn)
Subscribed
I have a question regarding the OEM Oil Temp...
I am using a Med9 ECU with the below details;
- ECU Hardware Number: 1K0907115A
- ECU Software Number: 1K0907115R 0020
The Oil Temperature doesn’t appear in the instrument/cluster, if I flashed the Med9 ECU by 1K0907115Q 0020 SW then the Oil Temperature appears in instrument/cluster.
I tried using the PolarFIS to see if it will work on it or not and I found the Oil Temperature appears with -60 with 1K0907115R 0020; then I flashed the same Med9 ECU with 1K0907115Q 0020 SW and I found the Oil Temperature appears and work normally in the instrument/cluster and in the PolarFIS too!
That means the wiring of the Oil temperature sensor is installed correctly and there is no problem with it.
Also, I tried all the above with ECU Hardware Number: 8P0907115B and same issue and results existed with it too!
Note: The Oil Temperature sensor is the VW OEM one not an aftermarket one.
What did you use to flash the revision "Q" software?
I have the Kufatec unit, but I can't see my oil temperature either.
Nitrous1024 is offline   Reply With Quote
Old 06-01-2019, 10:26 AM   #256
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
I used ODIS tool to flash the Q revision.
Don’t know much info about the Kufatec tool.
If the oil temp sensor is installed and connected to the ECU & Cluster then let me know the existed SW version you have.
Old 06-01-2019, 10:28 AM   #257
Nitrous1024
Originally Posted by CPT.SLO View Post
Wow crazy to think a GTI could be worth $100,000 in other countries, when you could pick them up for like $8000 in my area.
In Jamaica, my MK5 GTI is valued and insured at $J 1,850,000.
Today, the exchange rate is $132.8 Jamaican dollars to purchase $1 American currency.
Old 06-01-2019, 04:38 PM   #258
Nitrous1024
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G83NA8OV
Coding: 040300101C070160
Shop #: WSC 66565 257 00032
VCID: 354FD8585CDD5EECC7-8060
1 Fault Found:
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 178741 km
Time Indication: 0
Date: 2000.00.00
Time: 08:06:53
Freeze Frame:
RPM: 759 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
Readiness: 0110 0001
I don't "know" if the sensor is actually installed in my MK5 GTI, since I don't know where to check the sensor.
Is your copy of ODIS a genuine one or a clone? I'm trying to determine if the ones I see on eBay, can do software updates to the modules themselves.
Old 06-01-2019, 06:18 PM   #259
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 178741 km
Time Indication: 0
Date: 2000.00.00
Time: 08:06:53
Freeze Frame:
RPM: 759 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Voltage: 13.462 V
Buy this tool it works with me...
http://www.buyobdii.com/vas-6154-odi...ol-p-1599.html
Once you have it, I will send you the Q version.
The oil level/temp sensor located in the oil pan.
Old 06-01-2019, 07:03 PM   #260
Nitrous1024
In that case: Yes, I have that sensor bolted to my oil pan. I thought it was the oil level sensor to warn me if the oil level is low. I'm going to buy what you sent me right now.
Edit: I just bought it. It will take a few weeks to arrive to me in Jamaica.
Old 06-01-2019, 07:14 PM   #261
Mostic
FIA GT Champion
Mostic's Avatar
Drives: 07 MKV GTI
I will upload later the Odis Engineering and send you the link to download it so you can flash any .SGO file you may want/need.
