Old 07-16-2018, 01:09 PM   #1
exaurcism_666
Drives:
3 inch downpipe
does a 3 inch downpipe gives more power to a stock mkv gti?
Sent from my SM-N950F using Tapatalk
exaurcism_666 is offline   Reply With Quote
Old 07-16-2018, 06:10 PM   #2
vwengineer
FIA World Rally Car Newbie
vwengineer's Avatar
Drives: Golf 5 GTI (stock AXX)
No because what will give you power is the amount of boost, and the boost is limited by the ECU so even if a 3" downpipe could in theory give you more boost the ECU will limit it to stock values, the only thing you could get is more throttle response but you will also probably lose some torque due to the absence of back pressure from the 3" DP vs the stock one.
vwengineer is offline   Reply With Quote
Old 07-16-2018, 06:44 PM   #3
gti2slow
Formula 5000 Driver
gti2slow's Avatar
Drives: 2008 GTI UG 6MT
Backpressure myth is still going strong in 2018.
Driver Motorsport K04+ | RFD | EJ FMIC | EJ 3" Turboback | Peloquin LSD | SRE clutch
Neuspeed P-Flo | IE catch can | Brembo 17z BBK | Neuspeed RSe12 | RB 2-piece rotors
.:R32 Rear bumper | Votex lip | Koni coilovers | RCD510 | S3 short shifter | APR HPFP
gti2slow is offline   Reply With Quote
Old 07-16-2018, 08:46 PM   #4
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
Turbos donít make backpressure /s
eurocars is offline   Reply With Quote
Old 07-17-2018, 12:02 AM   #5
ROH ECHT
K04 PLAY
ROH ECHT's Avatar
Drives: 2007 mkv gti
No...will give no more power to a stock mk5 w/K03.
Unless you have done necessary mods to open up the throttle body, increase boost by a bunch with a much bigger turbo, and add fueling for those changes while keeping the balance correct for the compression ratio.
OEM is 60mm or 2-3/8". I run a K04 with a 2.5" Turbo-Back successfully and have done so with a tune that boosted over 26 psi. I would say do a 3" for a big turbo and fueling upgrades that make more pressure than what you could do with the oem lpfp and hpfp with internals upgraded...and custom tune for those increases.
On the other hand...the 3" DP will not hurt the power of a stock MK5. It will change the sound of the exhaust and this is likely why a number of people ride that Fanboy train.
K04 PLAYZOOMDIS!
GIAC K04&DSG files/AWE DV/Autotech HPFP/Torqbyte PM3/TTRS LPFP/S3 INJ's&fmic/RS4 fprv/FORGE fmtc,WG act.&TB HOSE/Techtonics TB/Custom Turbo Outlet/BSH Mounts/NEUS. P-FLO&throttle pipe/13.2"BBK/W.A.L.K./H&R SS/H&R F&R-ARB's/Bilstein B8 Dampers My Dragtime link-GIAC tune2007 Volkswagen GTI : 12.823 @ 112.050 MPH
ROH ECHT is offline   Reply With Quote
Old 07-17-2018, 12:24 AM   #6
5aprilc
FIA World Rally Car Champion
Drives: 2006 VW GOLF GTI 2.0T 6MT
Cat-less 3" downpipes for days!
5aprilc is offline   Reply With Quote
Old 07-17-2018, 07:17 AM   #7
vwengineer
vwengineer's Avatar
Maybe back pressure is not the correct term but my understanding is that restricting the exhaust size increase the exhaust gases speed which in turn brings positive benefits, especially at low RPM. A bit similar to restricting the intake at low RPM which gives more torque.
Thanks for correcting me if it's a false belief.
