Go Back   VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com > Members Area > Off-topic / Misc. > Video Gaming and Computing
Eurotek Tuning
Old 12-06-2014, 01:48 PM   #243
Callsign_Jester
traction is for pussies
Callsign_Jester's Avatar
Drives: '12 Mustang 5.0
My whole desk/rig/setup has changed since these pics in June. I redid the office a few months ago, but meh.
http://imgur.com/a/sH9VH
WC Parts list (sorta)
EK-FC780 GTX Ti
EK-FC780 GTX Ti Backplate
EK-Supremacy
EK-D5 Vario X-RES 140
EK-CoolStream RAD XTX (360)
EK Fittings
Mayhems Dark Blue
i5-3570K & GTX780ti inside of a Corsair 750D
Callsign_Jester is offline   Reply With Quote
Old 12-06-2014, 01:57 PM   #244
Callsign_Jester
Originally Posted by gti2slow View Post
Hers my rig. I custom made all the cables, super clean without any balls of wires shoved behind the motherboard.
I have been wanting to go to hard acrylic lines and water cool the video cards (Probably switch them out to 980's if I do) but have been too busy building rigs for other people to do much with mine.
Specs:
Intel i7 4930K
Asus Rampage IV Extreme black Edition
G.Skill 32GB (4x8GB) DDR2400c10
Samsung 840 pro 512GB
2x 2TB WD Black
2x eVGA 780ti classified cards + aluminum back plates
eVGA lighted SLI bridge
Corsair 900D case
Corsair AX1200i power supply
8x SP120 / 4x AF120 /1x AF140 Corsair quiet edition fans
Swiftech Apogee HD CPU water block
Swiftech MCP35x2 pump
Swiftech MCR420-XP quad 120mm radiator
Primochill CTR 250 res.
I suck with pictures: [pic]
Looks great, always been a fan of the black/white combo. What coolant are you using? Looks like coconut water!
Old 12-06-2014, 02:08 PM   #245
gti2slow
Formula 5000 Driver
gti2slow's Avatar
Drives: 2008 GTI UG 6MT
The res is frosted itself, its just filled with distilled water and a few drops of PT nuke. Planned on adding a white LED tube to light the whole res up but ultimately decided against it to keep it clean/simple.
Driver Motorsport K04+ | RFD | EJ FMIC | EJ 3" Turboback | Peloquin LSD | SRE clutch
Neuspeed P-Flo | IE catch can | Brembo 17z BBK | Neuspeed RSe12 | RB 2-piece rotors
.:R32 Rear bumper | Votex lip | Koni coilovers | RCD510 | S3 short shifter | APR HPFP
gti2slow is offline   Reply With Quote
Old 12-06-2014, 02:25 PM   #246
Callsign_Jester
Ah I gotcha, didn't realize the res was frosted.
Old 01-06-2015, 02:49 PM   #247
FaLLeNAn9eL
JESUS HATES FLAT TIRE
FaLLeNAn9eL's Avatar
Drives: black racek0r
Sweet! I have the same case and color combo and I'm running the same kind of coolant. I've actually added some glycerin to the mixture to act as a water wetter.
Originally Posted by RSMark5 View Post
That car has blown more tranny's than Matt
FaLLeNAn9eL is offline   Reply With Quote
Old 01-06-2015, 03:26 PM   #248
gti2slow
Formula 5000 Driver
gti2slow's Avatar
You have to be careful it does not react with the tubing, many will have the flex agent weep onto the inner surface. The only thing I have found that didn't have issues was Swiftechs coolant, I've used it in Tygon and Primochill tubing.
Old 01-06-2015, 04:26 PM   #249
FaLLeNAn9eL
Yeah, I've been using the distilled water/glycerin combo with Tygon tubing for years. Everything's in great shape and the coolant stays crystal clear.
Old 01-06-2015, 05:13 PM   #250
gti2slow
Formula 5000 Driver
gti2slow's Avatar
Awesome, ill have to try that.
Old 01-11-2016, 01:46 PM   #251
hemidesign
Oval Newbie
hemidesign's Avatar
Drives: VW GTI 2008 Castrol Edit. Grey
my $15k MotherBase PC
hemidesign is offline   Reply With Quote
Old 01-11-2016, 09:22 PM   #252
hairyblackrabbit
Powerful like a gorilla
hairyblackrabbit's Avatar
Drives: Malibu
explain 15k?
Originally Posted by Elliott View Post
Always good to learn. Was he older or younger?
Originally Posted by BlaineWasHere View Post
He's way older. In his 40s.
hairyblackrabbit is offline   Reply With Quote
Old 01-11-2016, 09:35 PM   #253
clownish
just clowning around
clownish's Avatar
Drives: Mk5 R32
Not a 15k rig but more normal...
i7, gtx670 and supporting pieces to use with some cheap dual ips monitors and a mechanical keyboard.
clownish is offline   Reply With Quote
Old 01-12-2016, 01:24 AM   #254
Waffle
Rally Car Champion
Drives: GLI Fahrenheit
Here is my 11k gaming rig.
4770K I7
GTX 660ti
Custom watercooling loop
2x Samsung 240 SSD
Asus Hero 5(I think)
Enthoo Primo Case
Waffle is offline   Reply With Quote
Old 02-18-2016, 04:00 PM   #255
FaLLeNAn9eL
It's been a while since I've posted mine. A little bit has changed.
Hardware:
Intel Core i7 920
eVGA x58 SLI3
Radeon HD6950
12GB Corsair Dominator
120GB Intel 520 SSD
250GB Samsung 850 Evo
3tb Seagate Barracuda Harddrive
850 Watt Silverstone Decathlon PSU
Corsair Obsidian 900D
Cooling:
Swifttech Appogee CPU Block
EK Full Cover Motherboard Block
EK Full Cover GPU Block with Backplate
Bitspower Crystal Link Acrylic Hardline Tubing
Bitspower Compression Fittings
Bitspower Tank Z-Multi 250 Reservoir
Swifttech MCP655 DC5 Pump
XSPC 360mm Radiator with Scythe Gentle Typhoon Fans
Mayhems Pastel White Coolant Dye
IMG_0731 by Bruce Han, on Flickr
Old 02-18-2016, 04:05 PM   #256
gti2slow
Formula 5000 Driver
gti2slow's Avatar
Hardware:
Intel Core i7 920
eVGA x58 SLI3
Radeon HD6950
120GB Intel 520 SSD
Cooling:
How hard was it to bend the tubing? The DIY's I've seen look deceptively easy. I want to switch over but really have been too busy to touch my own system.
Old 02-18-2016, 04:14 PM   #257
FaLLeNAn9eL
It definitely takes a little bit of practice but it's not very difficult. Buy more than you think you need and be patient, especially when heating it.
Margin of error is much smaller than soft tubing (we're talking millimeters) before it pops out of the fitting (I think it might be because the Bitspower fittings are much more lower profile than other, I'm not sure). So take your time.
The most frustrating part for me was the manufacturing variances between the tubing and the silicon strip used for bending (your mileage may vary). It was a really tight for me so getting it into the tube was a struggle. Lots of soapy water and twisting is the key to success.
Old 03-02-2016, 05:17 PM   #258
gti2slow
Formula 5000 Driver
gti2slow's Avatar
Is the connection solid? Not big on friction seals. I go to LAN events fairly often and it would be a disaster if they popped off while moving the machine.
Old 03-08-2016, 03:09 PM   #259
FaLLeNAn9eL
It's solid enough so that it won't pop out from side to side movement but it will come off if you pull on it.
The only thing holding the tube in is the compressed O-Ring when the fitting is tightened. Compared to soft-tubing where the actual tube is compressed, the connection is not as solid but it's still water-proof.
Old 09-27-2016, 12:01 PM   #260
Das Gespenst
Formula 3000 Champion
Das Gespenst's Avatar
Well I'm joining what's left of you. Just bought the new family PC/gaming rig.
AMD FX 6300 black edition
AMD R9 280X
8GB DD3 Ripjaw system memory
500gb HDD
25" HP monitor
Logitech G510 keyboard
Logitech G602 mouse
I'll get pics up soon. Not quite like most of the rigs on here but for $570 for everything not a bad setup.
Old 09-27-2016, 12:04 PM   #261
avenali312
Formula 5000 Champion
avenali312's Avatar
Drives: 2015 GTI
Oh man. I forgot about this thread completely. I'll have to post the build I did for my work computer.
Originally Posted by merkeyterkey View Post
So today I just walked right into Mordor.
I don't have pictures or directions, it was pretty neat though.
avenali312 is offline   Reply With Quote
Old 03-06-2017, 09:17 AM   #262
YBRmuggsLP21
Autocross Newbie
Drives: 2008 GTi
So are all the pretty lights on your case and whatever still cool or nah? Just wondering what the overall norm is these days. Seems like a lot of people are going to silent cases.
YBRmuggsLP21 is offline   Reply With Quote
Old 04-16-2017, 03:05 PM   #263
mister0wl
Drives: No car :(
I'm still playing on my old Lenovo y510p with dual GTX 755M's, but I'm hoping to build a gaming beast pretty soon. I'll definitely be back with that.
mister0wl is offline   Reply With Quote
Old 06-15-2019, 01:34 PM   #264
AlbertFroff
Newbie
Drives: Man
Send a message via ICQ to AlbertFroff Send a message via AIM to AlbertFroff Send a message via Yahoo to AlbertFroff Send a message via Skype™ to AlbertFroff
Voucher Google Play Gratis
Cara Mendapatkan Voucher Google Play Gratis
AlbertFroff is offline   Reply With Quote
Similar Threads
What is VAG COM moegreen DIY + Maintenance + Tips/Tricks 32 08-01-2008 08:19 PM
H&R Coilovers and Cup kit? Maximum6 Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 1 07-17-2007 09:46 PM
