#45 |
track sl00t
![]() Drives: mk5 rabbit, mk6 k04 gti Join Date: Oct 2016
So I pulled all of the fuses to inspect and none of them look blown. There is no diagram in this car showing which fuse goes to what so that sucks.
Mk5 Rabbit (Daily) Build Thread MK6 K04 GTI Build Thread Hit me up for Vagcom or DSG Service in Chicago (Cheaper than dealer/indie) |
#46 |
track sl00t
Also the lights on chime randomly stopped working and I left my lights on for about 10 minutes. Luckily the car started back up.
This thing is showing all the signs of having electrical gremlins that I don't want to deal with. Considering ditching it and buying something a bit more reliable.
#47 |
I'm Hella From Nor*Cal
![]() Drives: 08 .:R32, 69 Mustang 5.0 Join Date: Jul 2009
For the window, I would check your door harness for broken wires and check to make sure you don't have hella corrosion at the module. As far as the fuses, did you just look at them or did you use a test light or something to verify you have power on both sides of the fuse? With all the shenanigans going on it sounds ALMOST like a series of shorted wires
AWE-Forge-GIAC-Neuspeed-ECS-Eibach-EBC.... 220whp-250wtq ¤¤no more ![]() #4982 CW .:R32- stock- - ![]() |
#48 |
Also sc24 is the fuse for the 12v socket if I remember right or sc32 ....
#49 | |
track sl00t
As far as the wires being corroded, I'll have to find some time to pull the door panels and inspect the wiring.
#50 |
track sl00t
Someone tagged this sweet piece of street art on the rabbit. It's been shitty in chicago and there's no point in washing it
Lmao I got a laugh from it ![]()
#51 |
track sl00t
Got a chance to pull the multimeter out and find out where the blown fuse was for the 12v socket. Replaced the fuse and all is well in the world again.
Cool story I know.
#52 |
track sl00t
Thanks Obama
https://vimeo.com/201888041
#53 | |
Formula 3000 Champion
![]() Drives: 06 CW GTI DSG/09 UG GTI DSG Join Date: Jul 2011
Daily build (09 GTI) http://www.golfmkv.com/forums/showthread.php?t=195895 Racecar build (06 GTI) http://www.golfmkv.com/forums/showthread.php?t=186548 |
#54 |
FIA GT Champion
![]() Drives: 07 Candy White Gti Join Date: Dec 2013
Lol i have an rcd510 for sale. Those stock decks always do that crap.
![]() Last edited by Joshohol; 02-01-2017 at 12:51 AM. |
#55 |
Autocross Newbie
![]() Drives: '09 MkV Rabbit 2.5L Join Date: Oct 2012
#56 |
track sl00t
#57 |
track sl00t
Well, monthly update: My car's dash is now a christmas tree in true VW fashion. The ABS is still broken, not exactly sure what's wrong but the brakes feel fine... guessing the abs module is shot.
And I have a new problem now, the power steering assist stopped working and that caused another light. The car feels weird to drive now and the steering input sucks. Not sure where to even begin really other than lighting a match and setting it on fire.
#58 |
Conveyor Tech
![]() Drives: mk5 GTI, mk2 VR, mk1 Jetta Join Date: Mar 2016
If the ABS module goes, the electronically-assisted steering will shut off.
#59 |
track sl00t
They both happened at different times though, the abs module went first and the steering 3 months later
#60 |
So I did some research on this problem Jay, first thing to check is your fuses. There's 2 fuses associated with the steering rack that are somewhat common to go, could be a simple issue. As for the ABS module, highly unlikely the module itself failed since you're not an 09. There's a chance you could get the module reprogrammed at the dealership and fix that issue.
When you come over tomorrow bring your vagcom and let's see what the actual codes are.
#61 | |
track sl00t
#62 |
track sl00t
Also I officially don't like this car at all just for the record. Made a big mistake buying it :(
#63 | |
New York Giants Fanatic
![]() Drives: 2006 GTI 6MT Pkg2 Join Date: Nov 2006
I ended up finding a 2001 Civic for basically free with a bad trans, swapped in a low mileage trans and been driving it to work for 6 years / 60,000 miles trouble free. I know we like to talk shit about Civics in the VW scene, but damn are they hard to beat for cheap reliable transportation.
K04+APR+BillyBoat+Eurojet+Eibach+BBS+IE HPFP+SRE Clutch+JL-W7 |
#64 | |
track sl00t
#65 |
track sl00t
Came out to notice someone stole my mirror.
#66 |
That blows! Good thing I have a spare OEM mirror lense you can just have!
Thread Tools | |
