Old 02-01-2012, 05:15 PM   #1
Jambo007
Dont stop me now.........
Jambo007's Avatar
Drives: R32 MKV
Standard R32 Exhaust Valve
Hi Guys and Gals,
Im after as much information as possible with reference to the Valve in the rear box section of my standard exhaust system on my R32. What's it for what does it do? How is it controlled? I have 1 tip running a little sooty and 1 tip running clean is this a problem?
Cheers
Jambo007 is offline   Reply With Quote
Old 02-02-2012, 04:04 AM   #2
thezoneR32
Touring Car Newbie
Drives: MKV Gti Man
Im not sure of the exact workings but here goes. The valve is part of the bi-modal exhaust. At a certain rpm the valve opens and allows the exhaust to run straight thru the rear box. The pipes on this car get very sooty so not a problem just annoying. If you look at the exhaust there is a bit of piping that connects the system which you can cut and plug with a golf tee! This will allow the exhast to travel straight thru from start rather than waiting for the valve to open at 3000rpm or whatever. Its called the flapper mod.
thezoneR32 is offline   Reply With Quote
Old 02-02-2012, 03:07 PM   #3
Jambo007
Jambo007's Avatar
Drives: R32 MKV
Thanks for the info i'll have a look later today.........
Old 02-08-2012, 10:10 AM   #4
bazzle
Formula 5000 Driver
bazzle's Avatar
Drives: 2008 R32 Golf
It is open at idle, closer just above and opens agains at about 3200.
I cut my hose and blocked 1st day I took it home :) over 3 years ago.
You wont regret the change in exh note ;)
I used a 4mm hose joiner blocked with glue.
Bazzle
bazzle is offline   Reply With Quote
Old 02-08-2012, 04:16 PM   #5
Jambo007
Jambo007's Avatar
Drives: R32 MKV
Good one, i'll be on it this weekend........
Old 03-20-2017, 05:43 AM   #6
firreozkan
Drives:
How did it go
Skickat från min SM-G935F via Tapatalk
firreozkan is offline   Reply With Quote
Old 03-20-2017, 05:44 AM   #7
firreozkan
Drives:
Bazzle
Hey I want to get this done. What should I tell the mechanic?
