Old 11-10-2013, 10:13 AM   #67
zrickety
The Fixer
zrickety's Avatar
Drives: 2009 GTI 6MT, 2010 GTI DSG
Bumping a great thread. I'm running dual rings, but thinking hard about a quad setup now.
Originally Posted by flat tire View Post
Figure out how to epoxy it and get rid of the car ASAP.
Originally Posted by dustinwark View Post
Smart man, unfortunately I am the friend with the tools.
Originally Posted by GIACUser View Post
I like that it looks rather mundane and sort of a commuter car but is really a wolf in sheeps clothing.
True ESP OFF on 08.5-09 cars: http://www.golfmkv.com/forums/showthread.php?t=190211
zrickety is offline   Reply With Quote
Old 11-11-2013, 03:57 AM   #68
buckets
FIA World Rally Car Champion
buckets's Avatar
Drives: a tractor
Send them over mate, I will even do the fog lens bit for you! lol
Graphite Blue TDI | DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | InPro smoked indicators | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs
buckets is offline   Reply With Quote
Old 06-19-2014, 10:24 PM   #69
timj
Rally Car Champion
timj's Avatar
Drives: 07 Jetta - 08 DSG GTI
Send a message via MSN to timj
Thread revival
Sorry for pulling up an old thread guys.
Just picked up a 2009 Pirelli edition for the missus and have been wondering where you are all buying your parts these days.
I'd like to get a set of LED lights for the rear, doing the fog/reverse light change is pretty easy, did it to my own GTI back in 2008. Oh how I miss that car.
Cheers
Tim.
__________________________________________________ ______
timj is offline   Reply With Quote
Old 06-20-2014, 03:42 PM   #70
zrickety
The Fixer
zrickety's Avatar
I get many parts from ECS tuning or Keffervw.
Old 06-22-2014, 04:43 AM   #71
Booba
FIA GT Newbie
Booba's Avatar
Drives: MY08 Golf GTI MKV
i have a set of oem led tails if you are interested.
2008 MY08 Golf GTI | Bi Xenons | 5 Door | DSG | Anthracite Leather | Rear Parking Sensors
VW/Skoda Integrated Bluetooth | OEM Led Tails | Tein Euro w/EDFC
Booba is offline   Reply With Quote
Old 06-22-2014, 05:26 AM   #72
timj
Rally Car Champion
timj's Avatar
Hi Booba, shall PM you :-)
Old 06-23-2014, 06:31 PM   #73
timj
Rally Car Champion
timj's Avatar
Did you get the PM at all Booba??
Sent from my GT-I9505 using Tapatalk
Old 09-10-2014, 05:59 PM   #74
j9ysn
Drives: Golf Mk5 Edition 30
Originally Posted by DkN View Post
That is correct.
At this rate Craig your play money's gonna buy you some serious toys
I forgot about that - because your inners are on the same circuit as the middle circle on the outer lights.. Sorry to hear that mate.
Well to wire the inners to parkers all you'd need to do is cut the positive wires at your outers' plugs and crimp them to position 3 instead of 2 (or the other way around on the right side). Up to you which look you prefer but the switch itself shouldn't be hard.
Amazing job what you can do with Valeo's
Hope you guys can help. Sorry for the questions.
I wanted to know how to wire my inner led valeo tail lights to the outers to have park and brake without faults on the dash.
I understand that you have to wire the inner lights to the parkers and brake and switch that pin to the parkers pin position to have the inner lights work on parkers and brake. (Quad lights skyline effect)
What do I do with the brake pin I removed?
Is this the correct process?
Could you guys help what to do on vcds to clear faults and anything I'm missing please
Thanks guys in advance
j9ysn is offline   Reply With Quote
Old 09-14-2014, 10:35 PM   #75
buckets
buckets's Avatar
Drives: a tractor
Do you have LEDs in the inners? They don't come from the factory with LEDs in place. They have to be modded. Wiring into the car is the easy bit.
Old 09-15-2014, 04:14 AM   #76
j9ysn
Hi mate,
Yea in the inners are LEDs 👍 ready to be a baby skyline lol
Old 09-15-2014, 09:54 AM   #77
zrickety
The Fixer
zrickety's Avatar
Disable the cold diagnostics and you should have no errors.
Old 09-16-2014, 06:30 PM   #78
j9ysn
Cheers mate,
What's the best way of wiring to have the quad ring effecf for both parkers and brake?
Old 09-16-2014, 06:58 PM   #79
buckets
buckets's Avatar
Drives: a tractor
You'll have to experiment. I suggested early on in this thread to change the pin assignment in the loom to the outer. But I'm not sure it will work because of the way the system works. You could try getting into VCDS and setting tail lights to 0% then setting the "brake light as tail light" function to whatever value was for the tail light. If you get the dot only on the outer working as tail light and brake, then re-assign the pins in the loom plug as outlined above.
Old 09-17-2014, 03:11 AM   #80
j9ysn
Cheers @buckets!
Will play around and see what I come up with.
Probably just keep it tapped in to the parkers and keep it unique to the skyline as you said earlier in the thread..
Thanks for your replies guys I'll post pics with my final outcome
Old 11-06-2014, 03:30 PM   #81
buckets
buckets's Avatar
Drives: a tractor
Originally Posted by j9ysn View Post
Cheers @buckets!
@j9ysn - How did you go with the project? Been a few months and no pics.
Old 06-10-2015, 02:58 AM   #82
buckets
buckets's Avatar
Drives: a tractor
Update for those wanting this mod done
I'm now working with The Retrofitters for this mod. Those who want it can order the OEM Valeos through them and have them modded before they arrive to you. Mods include dual reverse, and the quad ring as DkN has had done.
Old 01-02-2016, 01:26 AM   #83
Roberts_J
Drives: MKV R32
Bump from the dead! Sent you a PM Craig.
Roberts_J is offline   Reply With Quote
Old 08-10-2016, 09:51 PM   #84
yacpro13
Newbie
Drives: Rabbit
@buckets
Hey Craig - bump from the dead part 2.
Do you still offer this mod?
Thanks!
yacpro13 is offline   Reply With Quote
Old 08-02-2017, 10:22 AM   #85
edvr6
Drives: Golf GTI MKV DSG
https://www.youtube.com/watch?v=zpH3FaRAJHw
Quad Ring
Dual blinker
Dual Rear
Dual Fog
edvr6 is offline   Reply With Quote
