Old 03-28-2011, 08:14 PM   #23
ecoterragaia
Touring Car Champion
ecoterragaia's Avatar
Drives: 2006 Toyota Tacoma 4X4
I'm not saying to go out and try this, but I added good dose of Chevron Techron Fuel System Cleaner to my tank and it greatly improved my slow/stuttering cold starts. HOWEVER, the reason I added it was because I was getting cold start misfires and was looking for a last-resort cure without replacing the injectors. The stuff did get rid of my misfire CEL's, but I don't know the long-term effects for the start condition or the misfires 'cause I sold the car 2months later.
Just thought I'd throw it out there. If you do try it, be sure to change the oil afterward, it turns pretty ugly and the cleaner reduces the effectiveness of the oil's additives.
ecoterragaia is offline   Reply With Quote
Old 04-01-2011, 05:17 PM   #24
Jerome81
Autocross Newbie
Drives: 08 GTI
I threw a bottle of Techron Concentrate in the tank yesterday. Not the Techron Injector Cleaner. Will see how it goes.
If no improvement, then I'll try a bottle of the Techron Injector Cleaner. If still nothing, then I'm gonna have to start going deeper....
SIDE QUESTION: Can leaking / leaky injector cause this cold start problem? Any way to test?
Jerome81 is offline   Reply With Quote
Old 09-20-2011, 04:42 PM   #25
JoeyGTI
JoeyGTI's Avatar
Drives: 06 UG, Pkg 2, 18" Hufs
I have also used the Techron Concentrate Fuel System Cleaner and it works amazing !! Cured my cold rough starts. I will be using this every 5000 miles from now on !!
JoeyGTI is offline   Reply With Quote
Old 03-13-2019, 01:44 AM   #26
livelight
Newbie
Drives: 2008 GTI
Bump
livelight is offline   Reply With Quote
Old 05-19-2019, 07:48 PM   #27
DeepBlue
FIA World Rally Car Champion
DeepBlue's Avatar
Drives: 2008 CW 4dr - NOT stock
Oh man... my car has been doing this for about 5 years!
No big deal. Checked and re-checked by everyone I could get to dig into this problem for me. Last thing I did was leave it with a highly reputable VW spec for 2 weeks. Could not find anything wrong with it. Car runs perfect otherwise.
After giving it a lot of thought, I decided that this is due to car sitting too much. Admittedly, I do not drive it nearly as often or for as long as I used to.
I now have a cold start procedure that is an effective workaround. It is as follows :
1. Get in car
2. Close door
3. Insert key / NOT turn
4. Tap gas pedal a few times (sometimes I tap brake too, sometimes I hold brake while starting)
5. Quickly turn key from off to start without any delay or stops in between
Car starts fine!
DeepBlue is offline   Reply With Quote
