Old 12-19-2010, 02:11 PM   #1
Jerome81
Autocross Newbie
Drives: 08 GTI
Hard Start When Cold
I've searched, I've participated in other threads, but I still can't seem to find much info on what is causing this hard or difficult starting problem when the car is cold.
Now that winter has hit and it is in the 20's outside, after the car sits for many many hours, I crank, and the car has sorta sputtered and died on the first start. Or I crank and it kinda stumbles to life. It has me bothered, but it seems nobody here has ever figured out if this is battery, plugs, coil packs, fuel pumps, etc.
Car runs fine otherwise. Perfect.
2008. Completely stock.
I'm thinking about taking it to the dealer, but I will need to get a ride from a friend, leave it overnight, etc. Its a pain.
If there are any new developments on what solved this issue, please post. May help when getting to the dealership.
Jerome81 is offline   Reply With Quote
Old 12-19-2010, 03:24 PM   #2
The Fed
Old Guys Rule
Drives: 2007 GTI DSG APR S1
Without a code it's difficult to diagnose. Sometimes impossible
Old 12-19-2010, 06:32 PM   #3
likes2driveslow
Oval Champion
likes2driveslow's Avatar
Drives: 2008 GTI FSI DSG
yeah i have this problem. it doesn't throw out a code so my stupid dealer can't figure it out.
someone on here suggested it's the low pressure (in tank) fuel pump. after reviewing some literature, that pump seems to change it's operating pressure depending on ambient temperature. this pump also doesn't throw a code.
next time i go to the dealer, i'm going to bug them about looking into that.
likes2driveslow is offline   Reply With Quote
Old 12-19-2010, 06:38 PM   #4
vagike
Newbie
Drives: 2008 GTI TR, 2001 Audi S4 VR6T
my does the same. Well, it has not stalled out on a cold start. I can definitely tell my battery is a touch weak when cold.
I would put a trickle charge (standard battery charger) on it overnight, and see how she starts.
if you do alot of short trip driving (less than 20min of driving) you are slowly killing your battery too. Especially in the winter, since you are running more electrical accessories (heated seats, rear defog, etc) you more power than usual from the charging circuit, and your car requires a long drive-time for it to charge itself back up.
//2008 MKV GTi // APR Fully Loaded Stage 2+ // ASA AR9 // VAG-COM // EJ CAI // EJ V-BAND DP // EJ Grenade DV // EJ OEM IC Upgrade // H&R touring Cup Kit // MK6 Climatronic controls // P3Cars Digi //
B5 S4 12v VR6T project
vagike is offline   Reply With Quote
Old 12-19-2010, 09:56 PM   #5
JimmerJam
Drives: 2008 GTI
I have the same problem some times. Other than that once it starts it is fine.
JimmerJam is offline   Reply With Quote
Old 12-19-2010, 10:25 PM   #6
Turbostream
Formula 5000 Champion
Turbostream's Avatar
Drives: 335i coupe 6speed
i believe its ur fuel pump sensor check it out. its like $40-$50 at the dealer. i had this problem back in the day
Turbostream is offline   Reply With Quote
Old 12-19-2010, 10:33 PM   #7
BoardSnow6
Drives: BMP Coupe Alpine Jetta Coupe
I believe that this problem is covered in a common problem thread... Id give you the link if i could find it...
BoardSnow6 is offline   Reply With Quote
Old 12-20-2010, 06:01 AM   #8
Ronan1
FIA GT Newbie
Drives: 2008 UG 5-door GTI DSG
Mine's a 2008 with 76k miles, and well maintained. I have had the same issue for months. In the morning, usually doesn't start first time, or takes a longer crank and then finally an uncomfortable start.
No codes. Changed the plugs, no difference. I haven't changed the coil packs, but I read on an earlier thread that someone with the same issue said changing their CP's made no difference.
I have not tried the fuel pump sensor.
Anyone else done this with success to this issue?
Ronan1 is offline   Reply With Quote
Old 12-21-2010, 03:04 PM   #9
Jerome81
Autocross Newbie
Drives: 08 GTI
Yeah, this issue still sounds like it isn't resolved. Bummer. Had hoped maybe I'd hear some sort of revelation.
I need to go to the dealer to replace the head unit ( CDC Hardware Error ) so I will talk to them. Not gonna leave the car overnight. last 2 days it started fine first try. Inevitably if I leave it at the dealer one night, the next day will be one of those days when it starts just fine....
And I'm pretty sure I have the fuel line rattle....which of course every time I get to the dealership is never occurring either.
I will ask what might cause it and the fuel pump sensor.
Old 12-21-2010, 03:41 PM   #10
Antagon3
Drives: 07 UG GTI
Quick and possibly stupid question, do you put the key in the crank immediately? Or do you put the key in, wait for the fuel pump to prime, then crank the motor?
I found that if I do the former, it'll sputter and sometimes die out. But if I wait a few seconds, she starts no problemo
Antagon3 is offline   Reply With Quote
Old 12-21-2010, 05:10 PM   #11
bigwill07mkv
Drives: 07 GTI
I have the same problem sometimes when its cold out.
bigwill07mkv is offline   Reply With Quote
Old 12-21-2010, 05:17 PM   #12
Wild Hare
.: MR. BIG STUFF :.
Wild Hare's Avatar
Drives: 2015 Golf R
I have the same problem as well. It's at the dealer right now for the Mechtronics replacement and to check on this cold start issue.
They've had it two days just to see if the cold start acts up. Nada so far.
Retired U.S. AIR FORCE
APR "high torque" Stage 2 / APR TCU tune / 034 CAI / 034 Dog Bone Mount / Neuspeed 25mm rear bar / Neuspeed FMIC / AWE Switch Path Remote
Wild Hare is offline   Reply With Quote
Old 12-21-2010, 06:59 PM   #13
nashbar
FIA GT Newbie
Drives: mk5gti, b5s4, fz1
the problem is a leaky check valve between the hpfp and the lpfp. it doesn't maintain enough pressure over several hours of being parked. it's fine as is, the lpfp runs when you open the door for a reason. just takes a few extra revolutions to get good pressure at the injectors.
nashbar is offline   Reply With Quote
Old 12-23-2010, 03:35 PM   #14
Ronan1
FIA GT Newbie
I have tried this and it really makes no difference in my case.
Old 12-23-2010, 03:37 PM   #15
Ronan1
FIA GT Newbie
Interesting. Is this based on you actually having the same issue and fixing it?
Where is this check valve located? Up till now, I guessed it might be a function of dirty valves since my car has 76k on it.
Old 12-23-2010, 10:44 PM   #16
Jerome81
Autocross Newbie
Drives: 08 GTI
Interesting advice. Anyone else have this as well? Repaired?
Old 01-18-2011, 04:33 PM   #17
Cabra
Oval Newbie
Drives: 2007 GTI
Having the same problem in my stock '07 Gti
Cabra is offline   Reply With Quote
Old 01-18-2011, 08:19 PM   #18
whitemkv
whitemkv's Avatar
Drives: 2006 CW GTI
check the battery, they shut down when its really cold. average life of a battery is around 4 years so yours is getting close. bring it to an auto parts store and have them do a load test.
whitemkv is offline   Reply With Quote
Old 01-18-2011, 09:01 PM   #19
kirkbar
Mod til I drop
kirkbar's Avatar
Drives: 09 GTI BMP 4DR DSG, TSI
Mine just started doing this too. Can happen right after I shut off - go for milk - and come back. Engine just about starts then sputters off. It's cold here 30F and wet. I have VAGCOM and no codes thrown.
I have an 09 with 25K miles.
2009 GTI 4DR DSG TSI | GIAC TUNE | AWE DOWNPIPE | MILLTEK R32 CATBACK | BSH RACE INTAKE | AWE TURBO OUTLET PIPE | S3 INTERCOOLER | S3 DV RELOCATE | BSH DOGBONE | KONI FSD / EIBACH PRO SPRINGS | H&R 24mm REAR | R32 REAR | R32 TINT TAILS W/ABMER LED TURNS | EURO SWITCH | FULL VENTED FOGS | HID PROJECTOR FOGS | OSIR FT LIP | BREMBO BBK | PODI GUAGES
kirkbar is offline   Reply With Quote
Old 01-18-2011, 09:20 PM   #20
GTIWV
WV VW
GTIWV's Avatar
Drives: 08 GTI, 02 S2000, 00 CRV
Send a message via AIM to GTIWV
Hell, you should be in mine when I start it up. Of course it sits a lot now, but it starts rough. lol. i figure part due to sitting, weather the s3 injectors, k04, tune and other factors. But as long as it starts, i am fine with it.
'08 CW GTI
APR K04
GTIWV is offline   Reply With Quote
Old 03-28-2011, 05:41 PM   #21
Jerome81
Autocross Newbie
Drives: 08 GTI
I'll resurrect this thread a bit.
I'm still curious if this leaky check valve is indeed the problem? Has anyone had success after having this replaced?
Is this something that I could replace myself? I have a feeling, as others have had too, that when I leave it at the dealer, the hard start will not happen. I'm tempted, if the part isn't too expensive and can be easily replaced at my house, that I may just try putting a new one in and see what happens.
I do know that when I open the driver door, I DO have that priming sound, so I know it isn't that problem.
Any other way to somehow test the lpfp with vagcom or have the dealer look, etc? Or is this one of those just-start-replacing-parts-and-hope-you-get-the-right-one kinda problem?
I just find it really really really really frustrating that this seems to be a pretty common problem on our cars, yet I just still cannot seem to get anything that indicates that XYZ is the problem part. Everyone still seems to be taking shots in the dark. It so odd. Most other problems this common have at least 1 or 2 known causes. This hard start is a ghost.
Old 03-28-2011, 05:58 PM   #22
HeartMyVeedub
FIA GT Champion
HeartMyVeedub's Avatar
Drives: 08 GTI FSI
Subscribed. I have this same issue and had my LPFP and HPFP replaced -_____-
APR Stage 2
HeartMyVeedub is offline   Reply With Quote
