Full Golf MKV GTI Pricing Information / Specifications (US and Canada)
JJ-R32
Administrator
Staff member
GTI INFORMATION THREAD / CANADA SPEC GTI (credit goes to CrssEyedNSmilin at vwvortex for this awesome info!)
- I've tried to supplement information where I could.
ON SALE: Jan/Feb 2006 (2 door); July 2006 (4 door)
BASE PRICE RETAIL: $21,990 (two door); $22,400 (four door); 6-Speed DSG add $1,075 (Destination charge of $630 for all orders.)
INVOICE PRICING (including options): - http://www.golfmkv.com/forums/showthread.php?t=38
STANDARD POWERTRAIN:
2.0-liter FSI turbo-charged I4
Bore: 3.20 in / 82.5 mm
Stroke: 3.70 in / 92.8 mm
Displacement: 121.0 in(cubed) / 1,984 cm(cubed)
Compression Ratio: 10.3:1
Horsepower (SAE) @ rpm: 200 @ 5,100-6,000 (147 kW @ 5,100-6,000)
Maximum torque lbs - ft @ rpm: 207 @ 1,800-5,000 (280 Nm @ 1,800-5,000)
Fuel Requirment: Premium unleaded (95 RON) recommended for maximum performance, (unleaded regular (91RON) as an alternative with slight reduction in performance)
TRANSMISSION: 6 Speed Manual, 6-Speed DSG (Dual Clutch Auto-Manual)
GEAR RATIOS:
Manual DSG
1 3.36 3.46
2 2.09 2.15
3 1.47 1.46
4 1.10 1.08
5 1.11 1.09
6 0.93 0.92
R 3.99 3.99
Final Gear Ratio (Gears 1-4)
3.94 4.06
Final Gear Ratio (Gears 5 & 6)
3.09 3.14
FUEL TANK CAPACITY: 14.5 gal / 55.0 L
FUEL ECONOMY (EPA Combined):
Man/Auto
City mpg 23/25
Highway mpg 32/31
CURB WEIGHT:
- from US GTI 2006 Owner's Manual -
Man: 3133 lbs
DSG: 3183 lbs
0 TO 60 MPH: 6.7 seconds (mfr; 6-Speed Manual); 6.2 seconds (6-Speed DSG)
TOP SPEED: Electronically Governed at 130mph
BRAKES: F/R ABS, vented disc/disc
STEERING RATIO: 15.6:1
TURNING CIRCLE (curb to curb): 35.8 ft / 10.9 m
WHEEL BOLT PATTERN & OFFSET: 5x112; (see GTI INFO THREADS below for detailed info on wheels)
EXTERIOR DIMENSIONS:
Wheelbase: 101.5 in / 2,578 mm
Front Track: 60.4 in / 1,534 mm
Rear Track: 59.7 in / 1,516 mm
Length: 165.8 in / 4,210 mm
Width: 69.3 in / 1,759 mm
Height: 58.4 in / 1,484 mm
Ground Clearance: 5.6 in / 143 mm
PASSENGER VOLUME: 94.2 ft³ / 2.7 m³
CARGO VOLUME: 15.1 ft³ / 0.4 m³
COLORS: Tornado Red - G2G2, Reflex Silver - 8E8E, United Gray- X6X6, Black Magic - Z4Z4, Candy White - B4B4
PACKAGES:
- 0 - (standard) High Intensity Discharge Headlamps and Washers, In-Dash 6 Disc CD-changer with MP3 compatibility, Real Brushed Aluminum Trim, Sport Steering Wheel with Radio and Trip Computer Controls, Power Windows/Locks/Mirrors, 17-Inch Alloy Wheels w/Summer Performance Tires 225/45 R17 (all season available), 3 Spoke Steering Wheel w/Radio & MFD Controls, Plaid Cloth Sport Seats, Fog Lights, ESP (electronic stability program)
- 1 - $1,370 package 0+ Sunroof and Satellite Radio (XM or Sirius)
- 2 - $3,160 package 1+ Heated Leather Top-Sport Seats (replaces Plaid Cloth Sports Seats in 0 & 1), Dual-Zone Electronic Climate Control, Heated Washer Nozzles
STANDARD EQUIPMENT LIST: http://www.autoblog.com/media/...1.JPG
STANDARD SAFETY EQUIPMENT: Driver and Front Passenger Front Airbags, Driver and Front Passenger Side Thorax Airbags, Side Curtain Protection® Supplemental Restraint Systems; Crash Active Front Headrests; and Daytime Running Lights (DRL).
SATALITTE RADIO: XM $375, Sirius $375
STAND-ALONE OPTIONS:
- DVD-Based Navigation System w/6-disc CD Changer (non-MP3) under Armrest $1800
- 18-Inch Hufweisen Alloy Wheels w/ Summer Sports Tires $750
- Rubber Mats and Trunk Liners (port-installed) $185
- Rear Seat Torso Side Airbags (4-door model) $???
WHEELS SPECS:
GLI/GTI stock Ronal 17" wheel - 17x7 et 54 - ~24lbs each
Monza/Detroit/Hufweisen BBS 18" wheel - 18x7.5 et 51 - 29lbs each
Karthoum 18" wheel - 18x8 et 50 - 28lbs each
ACCESSORIES: Accessories and Pricing can be found here: http://www.golfmkv.com/forums/showthread.php?t=5
>>>>2006 US GTI NOTES:<<<< Noobs! Please read these!!!
- The US Spec GTI is produced in Wolfsburg.
- The US Spec GTI does have a higher ride height than the Euro Spec GTI so as to gain higher crash test ratings. This can be adjusted with the purchase of OEM Euro Springs or aftermarket suspension.
- The US GTI has the same shocks as the EURO GTI!
- The US Spec GTI's Plaid Cloth Sport Seats are not as bolstered as the Top-Leather Sport Seats or Euro Spec Plaid Cloth Sport Seats.
- The cloth seats are not available as heated. Only the leather seats.
- A number of GTI's produced have open lower, side grill (where the fog lights are) where as a number have closed grills. Possible theories are that it has to do with DSG vs manual, or Tropical Zone cars vs standard... but neither has real grounds of evidence, so it is currently a mystery as to why there are 2 different grills. It is possible that at one time one of those theories was correct and VW decided to change policy.
- The rear taillights on the GTI are not LED, though aftermarket LEDs are currently available.
- The inner headlight on the GTI/GLI are flass to pass lights. Used to flash "brights" when driving with HID headlamps off.
- Launch Control (DSG only) has been disabled for US Spec 2006 GTIs but is expected to be introduced to the American market in the 2007 model year.
- The GTI is NOT available with Rain-Sensing Wipers, Auto-Dimming Rear-View Mirror, or Auto Headlights.
- The GTI does NOT have a 12v outlet above the Ebrake lever as GLIs and Jettas do.
- The US Spec GTI comes standard with the same 17" wheels that come standard on the GLI. The Euro Spec GTI 17" wheel ( a smaller, silver-painted version of the 18" Hufweisen wheel) will not be available on the US Spec GTI.
- The Phone Button on the GTI/GLI steering wheel currently does nothing. In the future VW plans to integrate an OEM hands free phone system for the American market. Dealerships can currently integrate a Motorola bluetooth system but the cost is extremely high.
- The GTI does NOT come with HomeLink.
GTI INFO THREADS:
- Extensive technical specifications for the GTI 2.0L Turbo engine. Golf MKV 2.0L Turbo Engine Specifications
- What taillamps are available for the Golf V? Information and Pics
PART NUMBERS:
Front Shocks - 1T0 413 031 EQ
Rear Shocks - 1K0 513 029 GP
Black "Shield" w/ Red Stripe: 1K0 853 653 B VW8
______________________________________________
2007 CANADIAN GTI INFORMATION: <--click for specs
ARRIVAL DATE: March/April 2006
PRICE:
MSRP/Models
2 Door 6 speed - $29,375 (1K19V2)
2 Door DSG - $30,775 (1K19V3)
4 Door 6 Speed (SOP 6/22) - $29,995 (1K1DV2)
4 Door DSG (SOP 6/22) - $31,395 (1K1DV3)
Excise A/C Tax - $100
Port processing fee - $20
Destination charge - $615
OPTION PACKAGE
'Luxury Leather Package' $2,580 (PG4)
- Power Sunroof
- Top-level sport front seats
- Leather seating surfaces
STAND ALONE OPTIONS:
- Power Sunroof - $1,400 (3FE)
- 18" Alloy Wheels (SOP TBD) - $900 (PJZ)
- Rear Side Airbags - $450 (4X4) Available on 4-door only
Interlagos Cloth Code
RZ
Black Leather Code
TK
(Part of package PG4)
NOTES:
- Though released in early 2006 the new mkV GT will go under the model year "2007" in Canada
- Many items standard on the US Spec GTI are not to be found on the Canadian GTI, even as options. Please refer to the Canadian GTI Spec sheet for all info on standard and option features.
- Launch Control (DSG only) though not available on the 2007 Canadian GTIs is expected to be available for the Canadian Market with the 2008 model year.
JJ-R32
Administrator
Staff member
Just added the Canadian Golf MKV specs. Click on the "2007 Canadian GTI Information" title above for the PDF.
LordNikon
Jeppe said:
Awesome info, but damn man! This is hard to read as a Dane. We have a 180% tax on cars making a base GTI cost $66K. I kid you not. :help:
woah thats crazy :eek: ...and I thought the GTIs here were expensive.
ewoo
Rally Car Newbie
BTW, the US spec GTI comes with the VW "Highline" (Upgraded) Multifunction Computer as standard. :w00t: In other regions, the Midline computer is standard.
CalgaryPilot
Newbie
Canada
Canadian price is out of line!
GRIPE:
Can anyone explain why the base MSRP price for a 3 door DSG is $26570 CDN ($23065 US) in the US but is $30775 CDN in Canada? Are Canadian buyers being ripped off by $4200?
I did a cost comparison with the MSRP for the Civic Si. It's ($20290 US) $23374 CDN in the US but up here the MSRP is $26080, a $2700 diference.
As I expected, in Canada the sat nav system on either car isn't even available as an option. Even on Canadian built cars such as some Hondas, they are available in the US market in year one but don't become available in the Candian market until year two or three.
I've enquired about both vehicles in Calgary. No dealer is prepared to move on the inflated MSRP.
dc_candy
DC
Maybe in the wheels spec section the rubber could be added. I don't know what the options are, but I do know that Both Continental and Bridgestone are offered as stock. Thanks...
Wantagti
insufficient funds
Apex, NC
Chevy Suburban Z71
MotorTrend said the 5 door is 20lbs heavier in this months write up. I wonder if they're wrong.
