Eurotek Tuning
Old 11-10-2012, 02:04 AM   #1
NahbutsGTI
EUROTHRASH
NahbutsGTI's Avatar
Drives: MkV TR 5dr GTI
Question MFD2 wont turn on with the car
Hi guys,
Got an MFD2 in my gti that wont turn on when I start the car. It turns on manually(with the power knob/button) but not when the car starts.
Any idea's? couldn't see any blown fuses?
NahbutsGTI is offline   Reply With Quote
Old 11-10-2012, 02:12 AM   #2
UGFast89
The Dubster Sith
UGFast89's Avatar
Drives: 2007 United Grey GTI
I'm having the same problem with my stock radio unit. Sometimes it turns on but its mainly off on startup. I'm hoping it's the battery. Hopefully someone could chime in on this.
UGFast89 is offline   Reply With Quote
Old 11-10-2012, 02:30 AM   #3
NahbutsGTI
EUROTHRASH
NahbutsGTI's Avatar
I just had my battery replaced and it started happening after that, I dont think its a battery issue...
Old 11-10-2012, 10:40 AM   #4
UGFast89
The Dubster Sith
UGFast89's Avatar
If it started happening after the battery swap then maybe you have a faulty battery. Did you get an oem one?
Old 11-11-2012, 10:27 AM   #5
NahbutsGTI
EUROTHRASH
NahbutsGTI's Avatar
Got a Yuasa battery, wasn't keen to pay for a narva!
Old 03-02-2013, 05:33 AM   #6
NahbutsGTI
EUROTHRASH
NahbutsGTI's Avatar
Hey UGfast, any luck with finding out what it is? I'm still having the same problem, have to turn the MFD2 on myself every time I get in the car. I end up doing entire trips without music without even realising!
Old 03-02-2013, 12:22 PM   #7
UGFast89
The Dubster Sith
UGFast89's Avatar
Swapping the battery did the trick for me.
Old 03-12-2013, 11:16 AM   #8
KevRob
Drives: Golf GTI MKV
I have same issue - waiting for my new battery to arrive from VW and then I can test this.
KevRob is offline   Reply With Quote
Old 03-22-2013, 06:15 AM   #9
bazzle
Formula 5000 Driver
bazzle's Avatar
Drives: 2008 R32 Golf
Put a voltmeter across bat.
Record readings with
car off
Ign on
Starting
Idling
Bazzle
bazzle is offline   Reply With Quote
Old 07-15-2016, 07:25 AM   #10
dimi_108
The GTI Collector
dimi_108's Avatar
Drives: 2 x MK5 GTI's & MK6 GTI
I know all of you boys have probably all moved onto greener pastures but did anyone figure this issue out? I'm having the same issue today after my battery died and got jump started back to life.
2005 MK5 GTI
2007 MK5 GTI
2011 MK6 GTI
dimi_108 is offline   Reply With Quote
Old 10-21-2016, 12:10 PM   #11
Maverick
Formula 3000 Champion
Drives: 08 GTI DSG Leather CW
Disconnect the battery for ten minutes, reconnect and test.
The head units are sent a command via CAN Bus when the car starts, sometimes for whatever reason this signal is not seen. A reset of the car seems to solve the problem but the issue appears to be the MFD2.
Also check your voltages.
website: www.my-gti.com
Maverick is offline   Reply With Quote
