Go Back   VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com > Technical Discussions > In Car Entertainment and Electronics (Audio / Video / Electronics / Etc..)
Ringer Racing
Old 06-19-2019, 07:12 PM   #1
toxic2597
Drives: 06 gti
Exclamation Need help with headlights please!
So when i bought the car the passanger headlight was always dim but recently the drivers side headlight is now just as dim. It was not a gradual getting dim like hid headlights do but i stopped and parked to go into a store and when i came back it was very dim. When im driving down the road its like i dont have the headlights on. I wonder if its the ignitor. Please help!
toxic2597 is offline   Reply With Quote
Old 06-24-2019, 05:14 PM   #2
3carmonte
Gelbrain
3carmonte's Avatar
Drives: 2007 Golf GTI Coup / FSI / DSG
Open invitation for the experts to jump in here and quash what I'm about to say but here it goes! Each headlight/daytime running light has it's own ignitor. The high-beams are "instant-on" lamps that don't require an ignitor. (Are they dim also?). I would start by measuring applied voltages on each side and comparing the circuits. Is the car idling smoothly? Do you have 12.5 to 13.2 VDC at the battery (engine off). With the engine running do you have 13.8 to 14.2 VDC across the battery terminals (alternator voltage)? How do your tail lights look? Normal? Last note, grounding issues can cause weird symptoms in lighting (and other circuits). Check for voltages drops between lamp grounds and chassis ground. More than 0.2 of a volt is an issue. Should be zero.
3carmonte is offline   Reply With Quote
