Searching the web for terms such as toe, caster, camber and bump steer will give you decent info on what effects they have on the car's handling.
Ian's group buy which includes caster correction kits and bump steer correction led me to ask why VW didn't improve on the bump steer in the first place? If bump steer is the evil of all cars regardless of street or race and ones aim is to eliminate it, then why have Whiteline been able to come up with revised tie-rod ends to reduce bump steer when one would assume (with the expected budget in R&D) that VW should have been able to come up with it in the first place.
Looking at the WALK kit I see pros & cons:
Caster kit
Pros
Please feel free to make any corrections if I have erred.
Interested in the bump steer kit, but just suspicious that Whiteline could have improved where VW couldn't on something that (to me) seems to only have negatives when you are at anything but zero.
Caster kit
Pros
- Better straightline tracking
- More camber in dynamic situations
- Heavier input required to physically turn steering wheel
- Increased NVH (from stiffer bushings)
