Looking for wheels that fit over them mostly. My current wheels should clear without a spacer but i would like options.
Also any reccomendation on pads and first hand accoints on pedal feel.
Need at least a 12mm.. I run a 15mmSorry to ask and resurrect the thread. Does anyone know if the OEM huffs will fit the 17z brembo kit without spacer or if I need a spacer how thick does it have to be?
Thank you
Sent from my BBD100-2 using Tapatalk
Do you have any pics by any chance?Need at least a 12mm.. I run a 15mm
Sent from my Nexus 6 using Tapatalk
They look awesome! Thanks for showing me this, so with the Serrons you used 15mm spacer? Did you have any fender rubbing issues?Those are the best I have on my phone at the moment. The Serrons have the same offset as Huffs and the Austins differ by 2mm
Same here..I think the height is same as yours. Thanks again! Here's my current ride height setup, I use the huffs for winter so wanna make sure I won't run into an issue once I upgrade to the Brembo kit. [emoji106][emoji106]Yes, 15mm. No rubbing with either set, but I do have my fenders rolled with fender screw mod..
