pete2528ca
- Thunder Bay, Ontario
- 2008 VW Rabbit 2.5
Got his last year, used it three times. Like brand new, still have original box.
This thing is fricken fast but lots of fun.
Chassis: TT-01 type ES, streamlined version of the TT-01 type E chassis-compatible with a variety of Tamiya Option Parts
Drive: Four wheel shaft drive Electronic Speed Control: Tamiya TEU-104BK with reverse, TAMM4541
Radio: 2-channel pistol grip 27MHz Tamiya Adspec AM, standard size and torque steering servo
Motor: 540 motor with pre-attached leads
Ball Bearings: Installed in differentials, bushings in wheel hubs
Shocks: Friction, plastic body
Gearbox: Sealed, front and rear
Differentials: Bevel gear, ball bearing equipped
Transmission: Single speed
Body: Painted grey and trimmed with mirrors, rear wing
Tires: Treaded 0.94" (24mm) wide, 2.6" (65.5mm) diameter
Wheels: 10-spoke gray 2.0" (52mm) outer diameter, 0.94" (24mm) wide
Bumper: Front foam
Suspension: Independent double wishbone
Camber: Non-adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Caster: Non-adjustable, caster/toe-in refers to the angle of the
front suspension when viewed from the side of the car in relation
to the chassis
Steering: Bell-crank type with servo saver
Paid $265 for the car plus $45 for the battery and charger. Looking for $250 or best reasonable offer. I'll cover shipping.
Bumper: Front foam
to the chassis
