Ok, I just did the intake valve cleaning on my 06 FSI @ 127K. I have had random cold start misfires on cyl's 2 & 4 for a while now per VCDS. This combined with a general feeling of sluggishness and laggy throttle response prompted me to finally tackle this project.
First the goods (good lord):
Cyl 1:
Cyl 2:
Cyl 3:
Cyl 4:
Filthy splitters (brownies anyone?):
It's pretty clear why I was misfiring on cyls 2 & 4. Yes, I have had a front PCV delete on the car for the majority of it's life, No catch can or VTA setup though. Castrol Syntec under warranty period and Rotella T6 currently.
A couple of notes:
-This tool setup works to get to the M10 triple square bolt (1/4" socket with 6" extension, hacked off M10 triple square bit in socket):
-Ended up pulling the throttle body off to gain access to the M10 bolt and dipstick tube, turns out it's not necessary - and as other have stated - it's a real PITA to get to the TB bolts. I would not remove the TB if I did this again.
-The 2 inner/lower access guides to the intake manifold bolts (on either side of the TB) will NOT fit a 3/8" extension! You need a 1/4" 6" extension and narrow T30 to reach these two bolts.
-My dipstick tube came off with almost no effort - a dealer visit years ago for a bad injector may have made subsequent removal efforts easier than a virgin tube might be.
-Crank bolt was a piece of cake to rotate (to close off open valves for scrubbing). This was with the front end of the car in the air, DSG transmission in Park.
My workstation:
I didn't get the valves as immaculate as a walnut blasting, but pretty close (no pics). Got her put back together today - car runs like new, perfect idle, pulls harder, couldn't be happier! I should have done this 60K miles ago - I had no idea the buildup would be this bad.
