You need a euro switch to turn on parking lights without headlights. Mine worked fine without needing vag-com but my DRL were not enabled.
Thanks for the info! ill have to look into that further!
Greg
hey guys.
im wondering if its possible for the vag tuner to turn off my drl's and turn on my parking lights when the car is moving with the headlights turned off?
currently my my headlights come on no matter waht as soon as the ebrake is disengaged.
and my parking lights(peanut bulbs in the highbeams) only turn on when the headlights are on.
can i program that differently?
A BIG :thumbup: to dpham00 for your vag-com doc!
I got my vag-com cable yesterday and couldn't wait to try it out. The documentation you put together made making changes to the programming a joy. I killed the DRLs, set the windows to open/close from the remote, told the car it was in Europe (it seems happier now), enabled leaving home, and more.
Vag-com rules and so do you, dpham00! Thanks again.
Any way to disable the city light underneath the headlight via VAGCOM? I only want amber when the turn signal(s) are activated. Someone recommended I pull the city light but that would probably result in a bulb out warning.
i vagged this weekend. great tool, couldnt be simpler thanks to dpham. killed drls, added window roll up/down feature, disabled horn, added leaving home feature. the one thing i cant figure out is how to use flash to pass w/ my high beams.Just got my Vag..
Still trying to understand how to use it..
