Vag-Com / vagcom Guide
rippie74
NJ
2008 GTI
I'm selling my HEX-USB-MICRO-CAN VCDS VAGCOM. Anyone interested shoot me a PM
JetTurbo
geezer
South Florida
changing service intervals
ok, i got a new one how do i set my service intervals to 4000 miles ?
I couldnt get that figured out either, i wanted to change mine to 6 or 7000. but i Could see to do is reset the service, change the service intervals to 5000,1000, and 15000...
You can set service interval distance in 100 km (62 mi) increments.
Service intervals are changed in the instrument cluster adaptation.
There are settings for both distance (in kilometers) in channel 42
and time (in days) in channel 41.
There is a sequence to be followed when entering these values,
it is shown in the VAG-COM help bubble when you access these channels.
To set 4,000 miles, enter 64 (6,437.376 km = 4,000 miles)
RHCP4LIFE
Eastern Iowa
.:R32
thanks!:thumbsup:
rolo402
08 Bunny 24/7
Los Angeles (Sun Valley) ca
Rabbit
Ok I had don't it but for like 400 miles I didn't really get it
Thanx
DasAutoMKV
It insists upon itself...
Houston, TX
07 RS MKV
I'm trying to Activate leaving home in 2009 VW GLI. I have byte 0 bit 5 but they dont seem to work. ANd I dont see the settings on the MFD. Am I missing something???
the true fastgti
I HAS BOOST
katterbach germany
2007 VW GTI
I had to install the euro switch for mi.e to work.
USING MY PHONE BYTCHES
ChattMkv
Level 80 Procrasturbator
Chattanooga, TN
2007 VW GTI
Amazingly useful guide. I now have my HID high-beams + 2500k FTP's + 2500k Fogs that can all be on at once and I'm loving it for dark country roads. Also did windows up/down, sunroof up/down, and got rid of the seatbelt warning and washer fluid warning.
Yakamakafane
Canada
Hey guys! I just got a vag-com and i have a little problem.. There is no text who appears with the bits to check .... anyone has seen this before? It's the version 10,6.
(sorry if my english is bad, i'm french)
the true fastgti
I HAS BOOST
katterbach germany
2007 VW GTI
Some times there is nothing next to the box. Not all boxes have stuff to change.
JetTurbo
geezer
South Florida
OP, in the long coding helper, do you find any text for any of the check boxes at all?
I thought Ross-Tech stopped doing that a while back,
i.e. if Ross-Tech did not find a documented feature for a bit,
in the more recent versions they removed the check box too. :iono:
older version of VAG-COM - Comfort System Central Control Module J393 Byte 0
current verison of VAG-COM - Comfort System Central Control Module J393 Byte 0
