rolo402
08 Bunny 24/7
- Los Angeles (Sun Valley) ca
- Rabbit
anyone know where i can get the 908 vag-com ???????
whats the difference between changing it to eu and leaving it in na mode? just want to know if its worth it of not wha are the benifits of changing it?
The most significant difference is US instrument settingwhats the difference between changing it to eu and leaving it in na mode? just want to know if its worth it of not wha are the benifits of changing it?
does not permit FTP with high beam when standard high beams are selected.
You can pretty much find a way to accomplish CH/LH, amber turns, fogs with high beams, etc
while retaining US instruments if that is your choice,
but you will not get quad high beams with US :biggrin:
i have mine coded to keep fogs on w/high beam. if i were to get coded to quad high beams, could i still retain the fogs as well or does it not allow for this?
Yes, fogs with high beam works the same with all country settings.i have mine coded to keep fogs on w/high beam. if i were to get coded to quad high beams, could i still retain the fogs as well or does it not allow for this?
I posted on a related topic with a description of the US / GB / EU differences here:
Inner headlights on US market GTI (Bi-Xenon equipped) - function and settings
scroll down to the section that starts with the MFD screenshots
I'm not sure if you can do it on a 07 GTI but you might be able too, I changed it on mine a few weeks ago. :wink:Is there a way to change the # of blinks when using the turn signals by slighting pressing. They currently blink 3 times when you press and release real quick.
Can you change it to 4 or 5 blinks?
only 2010 and newer can adjust the number of blinks per tap
The 2010 mk5 Jetta can also change the blinks and it's definitely a mk5. The mk6 Sportwagen is half-half. It's linked from both mk5 and mk6 FAQ but the page is under the mk6 subfolder because it's more applicable to those models.
How to change the number of blinks the turn signal makes per tap on your mk5-mk6 VW and CECM adaptation
Update: I've asked the owner why it says mk5-mk6 VW when it only says
He says
Sorry for the confusion.
just ordered the tool from ross-tech, just the CAN for my MKV R32 and It should work on my gf's B6 passat
