RKXtech response.
Your previous message
From my buddy Chris regarding the kit. He works on VW's all day long everyday.
"Yeah but they don't include the internal shaft seal that goes bad and causes the oil to leak into the vac chamber which in turn leaks past the outer seal. "
Is this true?
New message from: rkx-tech Top Rated Seller(1,753Red Star)
Hi,
The "vacuum chamber" is lubricated by the engine oil. If oil were not aloud into the chamber the plastic impeller of the pump would melt from the friction. The pump spins at half of the engine rpm at all times so when you have your engine wrapped out to 7000 rpm that little plastic vacuum pump impeller is spinning at 3500 rpm so oil in the chamber is critical and also completely normal. The pump is an "internally lubricated" component and has its own oil pressure supply to it.
I hope this helps and your question. Please do not hesitate to ask if you have any more.
Ryan
RKXtech
