kruegernaut
I'm from Detroit, Man...
- Washington
Sweet! anxious to hear what you think. I'm loving this mod even more now than I did last week.
After driving it for a week with the bracket installed, report back. We are here to help in any way possible. Here is a simple test to make sure you have it installed properly; with the leveling shoe not touching the master cylinder, idle the car and press the brake firmly. Keep pressing until it stops. In most MK5s and MK6s, the pedal will actually travel almost all the way to the floor(!). Then release the pedal, tighten the shoe per directions and repeat the same test. The pedal should now stop at least 50% sooner than without the bracket installed. Let us know! :thumbsup:
Hows it going GIACUser? Im bummed you didnt feel a difference. My pedal feel was significantly changed. Now Im wondering if I had something not right with my setup for it to change that much? The car brakes so firmly now. Whatever my braking system was lacking, this thing provided it. One thing that might account for some of our differences is we arent running the same rotors and pads. Mine is a cheaper setup. Maybe your stopping power is that much better than mine already? Just thinking out loud...
That was kind of my thought. The pads were much more aggressive than stock and require much less pedal pressure. I have quite a few miles on my current setup and I am pretty sensitive to changes and I honestly didn't notice any difference. I am going to do what Tyrolsport asked and check the install and report back so its not over yet. That was just my first impression.
Is it possible you have a little air in your system?
Based on Tyrolsport suggestion I have re-checked the install. I used my wife to operate the brake and hit them hard. I was seeing some movement I did not expect to see. It was actually a bit of lateral movement. I have turned the tension up by a 1/4 turn. I will drive in the morning and review.
Based on Junkers suggestion I am going to bleed the brakes again, that could be part of it. After driving it today I am noticing a diff but I also notice my pedal is sinking a bit.
More to follow, it is starting to be noticeable though only in a minor way so far.
