TT/S3 alloy arms & swivels Thread
laurent.d
FRANCE
A3 TFSI DSG S-line
So an update without much information.
I'm desesperate to found out more.
My last hope just gone, ther is no parts in stock anywhere all around Paris so I can't check the TT swivel shape.
So accoding to the ''Service Training Audi TT'' file and all what I could read on Forum a:
It seems that TT swivels need the use off TT tie rods which are much shorter than Golf/A3 on's. And fixing hole into the the swivel seems diferent. So it won't fit.
Moreover, nobody can validate that as ''Service Training Audi TT'' says, TT swivel widen the track. So it should widen the track.
I E-mailed Christoph BREUER from Raeder Motorsport in Germany who use to race an A3 in VNL Nürburgring race, and it seems that they use S3 swivel with a custom adjustable balljoint.
It seems that nobody in UK, US, France use TT swivel on Golf/A3.
So far, it seems that the only way to go is S3 swivel.
bostonaudi
Charleston, SC
1995 BMW M3
My .02, you'd get more performance gain from the H2Sport swivel with its much better roll center, than you will get from shaving a few pounds with the aluminum S3 swivel. Of course, both would be ideal. C'est la vie.
laurent.d
FRANCE
A3 TFSI DSG S-line
TT lower arms, ball joints and S3 Swivel ordered yesterday for me.:happyanim:
+ HPFP Cam follower and RS4 pressure valve, but it's another subject.
That's damn expensive!!
fuscobal
Romania
Just installed my summer 19''wheels and, with the TT arms, they sit about 8mm more towards outside than before measured on the upper side of the wheel (the tires get out of the fender now but fortunately they don't seem to rub) !
the bruce
land
Golf GTI Mk.V 2008
I'm going to fit the S3 hubs. S3 arms were fitted last year.
Is anyone able to confirm the part numbers?
Befestigung Bremssattel / caliper:
(S3:) N 910 849 01 = M14x1, 50x55 (8 Stück) (instead of Golf - N 909 488 02 = M14x1, 50x35)
+ nut WHT 000 237 A (8 Stück)
Klemmung Federbein / strut:
N 909 548 02 Schraube (2)
N 101 064 02 Mutter (2)
Mutter für Führungsgelenk an Schwenklager / nut ball joint and hub:
WHT 000 785 (2 Stück)
Mutter für Führungsgelenk an Querlenker / nut ball joint and arm:
N 103 320 02 (oder N 909 429 01 ?) (6)
Schrauben für Silentlager an Aggregateträger / bolts rear bush (alk):
N 105 607 02 (oder N 105 797 01 ?) (4)
Schraube Silentlager an Längsträger / bolt rear bush to chassis:
N 910 398 02 (oder N 908 235 01 ?) (2)
Schraube für Querlenker vorne an AGT/Konsole / bolt arm to subframe:
N 101 410 01 oder ...03 (2)
Zwölfkantbundschraube Radlager / bolt wheel bearing:
WHT 002 795 (2)
the bruce
land
Golf GTI Mk.V 2008
WHT 002 795 (2)
anyone ??
:cry:
:headbang:
fuscobal
Romania
Can't confirm the part numbers but I've just purchased the S3 hubs + bearings + speed sensors from a guy. I will install them in about 2 weeks and make some detailed pics. I just have to see if I can keep the TT arms in the correct position or with the ball joint on top !
the bruce
land
Golf GTI Mk.V 2008
Let me know about it. I'm going to do the same.
the bruce
land
Golf GTI Mk.V 2008
(early) Passat arms = Leon Cupra arms = S3 arms = RS3 arms = Sharan (2011) arms
Only the rear bushing differs. Same geometry as Golf. Cupra/S3/RS3 rear bush is solid rubber.
fuscobal
Romania
S3 hubs are here. They weigh 2.9Kg each (with the sensor). I will weigh my iron ones when I get to switch them !
bostonaudi
Charleston, SC
1995 BMW M3
S3 bushings are stiffer than GTI but not quite solid rubber. The TT-2 bushings are solid rubber.
