I did some reading on other threads, but the scenarios didn't relate to mine so here it goes...
I took a road trip to Ohio from NC today and while cruise control was engaged traveling at 70-75mph going up a grade/hill/whatever I would feel a sudden jolt/shudder. Boost pressure would not drop and the exhaust didnt seem to make any unusual noises. I hopped off the highway and checked the coil packs to make sure they were seated completely in the engine and also plugged into the harness. One plug seemed to go down about a millimeter or two. Got back in the car and hit the road...never had an issue again.
When I finally arrived in Ohio I charged up my laptop and checked out engine misfires on cylinders 1-4. All of them seemed to see 1-2 misfires while cruising around normally and even a few when lightly reving the motor while the car was in park. None of the cylinders exceeded 2 misfires and I no longer feel the jolt/shudder.
Is this something I should be concerned about? No CEL or soft codes (which from what I've read is not unusual) in VAG-COM. If I really give it some gas then I get no misfires so it only seems to be affecting consistent driving conditions. The car has just over 47k miles on it. Time to swap spark plugs or coil packs?
