Torque specs?
Helistyle
www.lowmain.net
CT
Ride
2006 GTI
I plan on installing some springs coming soon on my 2006 gti 2.0, and was wondering if there is somewhere that has the torque specs on all the bolts and such?
ik1015
beeee patient ^^
VA
Ride
MK7 GLI
FRONT TORQUE
Suspension strut mount to damper
Use new nut
60 Nm = 44.25 lb-ft
N-910-216-01 x 2
Suspension strut to wheel bearing housing
Use new nut
70 Nm + quarter turn (90°) = 51.63 lb-ft + 90°
N-101-064-02 x 2
Suspension strut to body (suspension strut tower)
Use new bolts
15 Nm + quarter turn (90°) = 11.06 lb-ft + 90°
N-101-277-07 x 6
Ball joint to control arm
Use new nut
60 Nm = 44.25 lb-ft
N-103-320-02 x 6 -???
Connecting link to suspension strut
Use new nut
Counter hold at joint pin inner multi-point fitting
65 Nm = 47.94 lb-ft
N-015-081-6 x 2
Drive axle to wheel hub “hex head bolt”
Use new bolt
200 Nm + one half turn (180°) = 147.51 lb-ft + 180°
N-910-406-01 x 2
Drive axle to wheel hub “12-point bolt”
Use new bolt
N-101-064-02 x 2
REAR TORQUE
Lower control arm 2 wheel bearing housing
Use new nut
90 Nm + quarter turn (90°)
N-106-286-01 x 2
N-101-064-02 x 2
Rear upper strut mount: 37 ft/lb + 45degree turn
Shock lower mounting bolt: 133 ft/lb
Wheel LUG BOLTS
88~89 ft/lb
apollosfury
designeddwk
VT
FRONT TORQUE
Use new nut
60 Nm = 44.25 lb-ft
N-910-216-01 x 2
Use new nut
N-101-064-02 x 2
Use new bolts
N-101-277-07 x 6
Use new nut
60 Nm = 44.25 lb-ft
Use new nut
65 Nm = 47.94 lb-ft
N-015-081-6 x 2
Use new bolt
N-910-406-01 x 2
Use new bolt
N-101-064-02 x 2
REAR TORQUE
Use new nut
N-106-286-01 x 2
N-101-064-02 x 2
Wheel LUG BOLTS
88~89 ft/lb
good to have these #'s just in case.
CameronR
Canada
Bump! I am looking for the torque specs for the balljoint to spindle nut (large single nut facing up, not the three that point down. Also, the front control arm bolt.
thanks!
Cam
