Driving along, I had a sudden thump after acceleration. The thump felt almost like I hit a pothole (it wasn't an actual pothole I hit). Parked to do some grocery shopping and when I got back in the car, everything ran fine but as soon as I accelerated out of the parking lot, I had bad misfires on cylinders 2 & 3 all the way home.
I've let the car sit for a while as well as cleared the fault codes but the misfires on cylinder 3 remain even at idle. I'm going to check on the basics tomorrow when there's light out like plugs and coilpacks. If the misfires remain in the same cylinder, then I'll know its either a compression, fuel, or injector issue.
How likely is it that this is a compression issue? I can deal with pulling the intake to change out injectors(and clean the valves while I'm in there) but a blown piston ring or head gasket is way outside my comfort zone.
I did search but didnt see any threads that involved a random misfire that started a recurring misfire.
