donjuan1jr
whats a turbo?
- East of queens west of hamptons
9:1 should be fine alone, i wouldnt go extremely low on this motor.
Taking opionions on lowering compression with a headgasket, I know some of you have done it, two questions, is it worth it if I have 9:1 lower mahle compression pistions already and where can I get a head gasket that is for overbored 83mm pistons?
I'm running 9.5:1 pistons with ppg thicker head gasket. No complaints here. I can run 26-27psi on pump with no concern. It leaves some room for error
Getting there. DSG files are pretty much finished, now to work on the suspension and the open diff is finally showing its weakness at 500+ whp. Alot One tire fire in first and blowing off tires in 2nd and part of 3rd
Car 790
So that equals around 8.5:1? I'm running the thinker head gasket that is suppose to put me at 9.5:1. I have no big turbo fsi experience on stock comp so I couldn't tell you if it's better/worse/same
Car 790
Take solenoid to home depot or advance and use their thread chart...
So I did that without success. I finally got in touch with gizzmo USA. They didn't have a clue but they contacted gizzmo in Australia. It's 1/8" BSP(British Standard Pipe).
