phil why would i need the catch can over this ?
Under what scenarios would you NOT have a rear check valve. is it one of those "if you removed it you dont have it, if you didnt touch it you do have it"
different pcv versions have different check valves. my 06 didnt have one at first. but once i got a new pcv kit, then that came with the check valve. to remove the check valve u just need to take off the rear pcv and push the check valve with a screw driver. and thats it
so you dont actually remove it.. you "push it with a screw driver" to jam it up?
I did it with my thumb. It pops out.
