Suspension upgrade
The_Tankwhisperer
Germany
Mk.5 GTI
I wanted to ask if anybody had some advise on which upper suspension-strut bearing i should/could use for my setup. I have Eibach Lowering Springs and want to install Bilstein B8 Dampers.
ROH ECHT
K04 PLAY
PDX OR
2007 MKV GTI
I would use OE for both. I've replaced just one upper bearing for damage and it was after I allowed a shop to install the first set of springs over ten years ago. Not sure if they did something but they were not taking responsibility for it so I just went and replaced it.
I just added a fourth set-up of springs, the first being Sportlines, and I always add new OE bearings when I do this. Perhaps the next time I remove the struts, I will replace the upper mounts as well. I too have B8s so it may take some time before the need to do this arises.
034 motorsports street density would be a mount upgrade for the 50% higher durometer...but his means less absorption. So you can try it and decide if it helps handing out more than the comfort it loses: https://www.ecstuning.com/b-034moto...aCn-Gpt_3_aiXOMZIXFK0K4aoe17eh5BoCuyMQAvD_BwE
As far as a bearing upgrade goes....I don't think it is necessary and thus unavailable. But I again would stick with OE or the original maker of the OE bearings before trusting just any OE replacement part.
snobrdrdan
former GTI owner
I'd avoid the 034 mounts
The TT mounts I linked won't be a "drastic" upgrade, but they are a slight upgrade & OEM quality still.
If you want OEM though, just grab the Lemforder ones for cheaper ($20/each), which is the OEM supplier to VW for those:
https://www.ecstuning.com/b-lemforder-parts/front-upper-strut-mount-priced-each/1k0412331b~lem/
Versus the VW markup of $63/each for the same exact part:
https://www.ecstuning.com/b-genuine...ont-upper-strut-mount-priced-each/1k0412331b/
And while I do agree on changing the rear shock mounts too....I'd just grab the Sachs version for way cheaper ($16/each), which is the OEM supplier to VW for those:
https://www.ecstuning.com/b-sachs-parts/rear-shock-mount-priced-each/1k0513353g~sac/
Versus the VW markup of $71/each for the same exact part:
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/rear-shock-mount-priced-each/1k0513353g/
