GolfLeFleur
- Calgary AB
Greetings,
I bought a 2007 MK5 GTI in November of 2017, had a busted dv so i replaced that with the newest revision shortly after, end of July this year HPFP and cam follower both went belly up and those were replaced. When I first bought the car, it would accelerate no problem under heavy load from 0-100km/h and passed that no problem rolling 60 to however fast i was going, no problem. Then my HPFP gave me troubles and thats when I was introduced to the world of VW things that die. These were promptly dealt with, thought it seems like the intake cam lobe has been scratched and slightly grooved. I was not able to clear codes like I should have (rookie mistake) I know that the computer will reset itself in given time. Symptoms before were, low engine performance, poor acceleration, intense bucking under load, and soft limp thought the engine never truly limped and shuttered.
What I've done since November:
Replaced DV with newest revision
New OEM hitachi HPFP + cam follower
New NGK Iridium spark plugs
Since these items have been replaced and fixed, I still get a soft limp, there is no dash light that flickers on or stays on. Ive been thinking about replacing my ignition coils as I have an outdated revision (couldn't read part # because spark plugs were just before leaving for vacation and didn't have the time). I nearly shit myself almost getting into a head on collision with a car after trying to pass a semi on the highway and i accelerated and the car starts to quickly build boost and let off as i am trying to pass and will not let me go any faster. Gradual acceleration at high speeds are fine but hard acceleration (like in the situation of passing on dotted yellow) was impossible. I went for a couple test drives after clearing codes and it was smoother but this soft limp won't go away, 0-100km/h foot to the floor, no acceleration. Any advice and or knowledge helps, I have tried to find someone with similar symptoms but haven't found anything. Ive heard everything from spark plugs to ignition coils to injector cleaner to pcv valves etc etc.
Thanks
Thanks
