Something a little different
apollosfury
designeddwk
VT
the chrome on my original dsg shift knob was peeling pretty good, so after some looking around i figured out how to take it off and in the process found an alternative solution called the 'tip mod'.
how do take the dsg knob off
http://www.golfmkv.com/forums/showthread.php?t=142940
the tip mod is designed to make it so that you can use any shift knob on the dsg/automatic shift post. the pics will illustrate how it works...
bare post with shift engage loop
tip mod installed. set screw feeds through the loop allowing one to just pull up on the knob to engage/disengage
tip mod and knob installed
obviously there's no shift boot yet, but i'm in the process of making one since i can't seem to get the dsg knob and boot to separate.
i would've liked another dsg knob, but $300 is insane to me for such a part. The combined price of the knob and tip mod was $90. i picked up the knob for $20, the tip mod is $60. The last $10 comes from taking the tip mod to a machine shop to have a second set screw hole drilled and tapped. It is designed for a more standard automatic where the engage loop is turned 90 degrees from the dsg set up.
some others have just gotten a manual boot and surround, but for the sake of honesty i'm planning on keeping the dsg surround. the beauty is that if i ever tire of this knob, i can pick up a new one :thumbsup:
freshpots
r'zub n t'zug
Toronto, CAN
2007 GTI
Wow, that's sick. Post pics with a boot!
apollosfury
designeddwk
VT
thanks everyone. shift boot is about a week out from being done
RevoGLI
i <3 canada land
Berkeley, CA
2006 GLI
are you going to do a shift boot swap with a manual base plate?
or are you just going to keep the dsg plate in place?
I'm rocking the dsg knob with a manual shift boot swap.
apollosfury
designeddwk
VT
i plan on keeping the dsg base.
apollosfury
designeddwk
VT
Update. Suede boot
Sent from my ASUS Transformer Pad TF300T using Tapatalk 2
Prana
Since 88'
Miami
Looks good man. It would look even more inconspicuous if you swapped the dsg plate for a manual surround trim.
