00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Sporadic communication error 1000
19-CAN Gateway -- Status: Malfunction 0010
000051 - Turbocharger Bypass Valve Control Circuit: Malfunction / Open Circuit
P0033 - 004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 7
Mileage: 25392 km
Time Indication: 0
Date: 2000.00.00
Time: 16:49:33
Freeze Frame:
RPM: 722 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 46.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.462 V
Readiness: 0000 0001
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0020
Revision: H04 02 Serial number: 26080602000934
Coding: 7F8F03400F000000
Shop #: WSC 01279 785 00200
1 Fault Found:
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 77
Mileage: 30876 km
Time Indication: 0
Date: 2000.00.00
Time: 09:51:49
I'm pretty sure the first one is because the stock dv in my car is just not being used since I'm k04 and using a relocation kit. The second one I have no idea. I'm taking my car in for the 20k service and I'm hoping the take care of it but it would be nice/informative to know whats going on with that. The CAN gateway I'm pretty sure is because I plugged in the vagcom w/out having the drivers on my comp (had reformatted and forgot).
For the sporadic communication error I don't know if this has anything to do with it but when my a/c is on sometimes I hear a chirping noise from the glove box area. Sounds like a cricket.
All help appreciated.
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Mileage: 25392 km
Time Indication: 0
Date: 2000.00.00
Time: 16:49:33
Freeze Frame:
RPM: 722 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 46.0°C
Voltage: 13.462 V
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 77
Mileage: 30876 km
Time Indication: 0
Date: 2000.00.00
Time: 09:51:49
