RacerFreddy
- Pennsylvania
- Mk5 GTI
Simply put, I got the MAF issues sorted out a bit, fuel trims still sit a bit high +9-10%, and I still have high RPM stutters. APR's tune *cough* *cough*. In the future I will be looking into a hybrid intake combining my two cold air intakes and the stock MAF housing. That's for another day.
The problem now, is ever since I fixed my bum S3 injector and put on my Twintercooler, I've had horrible idle issues and cold start misfires. I have done the following to correct as much with fuel trims and air leaks as possible. Alongside general fixes to help my chances.
- As mentioned above the car now runs in spec under load, +1% at idle at the moment, due to replacing a MAF sensor to a very OE spec one.
- Checked for and repaired various air leaks, both in the intercooler piping and the vacuum system. PCV is deleted, and the lines for rerouting are free of leaks as well.
- Refreshed a load of sensors (aside from the MAF)including the ones on the HPFP, the MAP sensor, the IAT sensor, and the front O2.
- Coils and plugs are the newest version of the Red R8 coils (full rubber sleeve) and NGK PFR7S8EG (OE plugs)
- When replacing the injector I got a new top seal, but left the teflon one alone, and the valves looked pretty good, had cleaned them previously.
- Cam follower is regularly checked, and since switching to Rotella oil and upgrading to K04, the wear is really slow now, not much of a concern at the moment.
So here's the rub, my idle fuel trim is at +1% at the moment, but the lambda is reporting a pretty constant subtractive trim in the lambda control, meaning it is pulling fuel. Makes sense right, the S3 injectors are bigger, and maybe they don't need to stay open as long at idle. APR's tune also runs richer all the time I hear.
However... this is still causing the misfire/sputtering at idle, almost like a cylinder is being flooded. It's popping and almost backfiring somewhat aggressively only parked at idle. It's only cylinder one that gets hit very hard by this, which is the location of the injector I had changed to the OEM S3 injector, so it matches the other three.
Using VCDS I went into basic settings today and ran the lambda control shut off adaptation, which at full operating temp where the car pops the most, it shut down the front 02 and lo and behold it stopped the live adjustments to fuel trim, and stopped the popping and misfiring.
TLDR... Why when the O2 is turned off in the adaptation and live trim adjustments stop trying to pull fuel from a obviously rich idle does this stop the misfires? Is it possible something is throwing off the front 02, usually that would be an exhaust leak, but that would have it reporting lean, not rich. A really hard question I know, but that's the only thing in all my testing and logging that has thrown up a red flag.
My thoughts are either 1. it's all tune related and I need to switch, looking at Untironic because of Uniconnect and the flexibility of dialing in parameters for different parts in use and flashing to stock as needed. Or 2. That one injector is either still bad, the spray pattern is whack, or the seal is bad, and I need to go in with a whole new set of S3 injectors and just hit them all while I'm in there, and maybe check for carbon buildup again.
Either way I see it I'll be out 500-1000 buckaroos, but I really want this thing to run right, I haven't been able to fully enjoy K04 for a full year now, and just am over the constant small issues.
Thanks for reading my wall of text guys, let me know what you think.
