dpham00
Modérateur Emeritus
- Los Angeles, CA
Chip FAQ
This guide only talks about the 2.0T chip, however, many of the topics apply to the 2.5, 3.2, and TDI as well. Not all chip vendors have a program available for all engines. This guide is mainly for people in the USA. This is still a very rough first draft, just wanted to see what you guys think. Please let me know if you have any suggestions, or if I made a mistake somewhere.
What is Chipping and how is it Different From Stock Software?
For the MKV, chipping/flashing/ecu upgrade refer to the same thing. Typically, an aftermarket manufacturer will acquire the stock ECU code, make some modifications to improve performance, including, but not limited to, boost, timing, and fueling. Most chips also slightly raise the rev limiter, and remove the speed governor. The chip is this modified ECU coding which is then installed on customer’s cars.
-All 2.0T chips increase boost.
-Some 2.0T chips will maintain similar to stock air/fuel ratio.
What Do I Need Before I Install a Chip?
Nothing! All chip vendors provide a chip that will work with an otherwise stock car. An upgraded DV (only applicable on the 2.0T) and PCV is recommended, as they have a tendency to fail when chipped, however, you can wait until they fail before replacing them as well.
Note that some chip vendors also provide additional software that can be used with additional mods such as an exhaust or a turbo upgrade.
What’s Involved in Chipping?
In the old days, chipping involved physically opening the ECU and soldering in a new chip. Those days are gone. All major MKV chips are flashed through the OBD2 port under your dash.
Performance:
The chip by far is the best bang for the buck in terms of performance. Most chips in the US will provide similar power gains.
Note:
-These numbers are provided by the manufacturer’s websites and are for a chip only.
-All power gains are at the brake horsepower (bhp), meaning they are crankshaft/flywheel HP, not wheel HP (whp). Most dyno plots show WHP. Also, dyno plots are really best used for tuning purposes as they can vary substantially based on the dyno and ambient conditions.
APR
91 octane: 246hp/282lb-ft
93 octane: 252hp/303lb-ft
GIAC
18-50hp and 50-85 ft-lbs gain
REVO
250hp/285 ft-lbs (http://www.revotechnik.com)
These graphs where taken from (http://www.revotechnik.com.au)
Yes, I know the graph conflicts with the stated values. 98 RON is about 93 AKI (rating used in the US), though this is a very rough approximation.
Unitronic
245hp/277lb-ft
I could not find dyno plots on Unitronic’s website
Dahlback Racing
244 hp (180 kW)/ 265 ft-lb
SpeedTuning
249 hp / 360 N*m (266 ft-lb)
**Note that the stock graph is not accurate because the 2.0t is underrated from the factory and will produce substantially more than what it’s rated at.
O.CT
235hp / 350 N*m (258 ft-lb)
Green=stock torque, yellow = O.CT torque, cyan = stock hp, red = O.CT hp
Trial Software/Moneyback Guarantee
Both REVO and APR offer free trial software. Note that the installer may, at their discretion, charge an installation fee even on the trial software.
-Some manufacturers have said that they could chip over another manufacturer’s software. If you plan to do this, then you should check with them first. What I mean by this is if you go from the REVO trial to the APR trial.
-GIAC/Unitronic does not offer a trial software, however, they do offer a 30 day money back guarantee.
What Chip Should I Choose?
IMO, you should choose a local dealer who is knowledgeable and has good customer support among GIAC/REVO/APR. These are the biggest and most popular vendors out there and they have a wide network of dealers.
-Local is important because you don’t want to drive 4 hours just to get reflashed when the dealer flashes you to stock, or if you want an upgraded and/or newer flash. Keep that in mind when choosing who to go to.
-Good customer service is important – you don’t want to get a chip and when you have a problem, the dealer who installed it might not help you out. Talk to people in your area to see who they’ve had a good experience with.
-Look to see if they have a big dealer network base. A small network base isn’t necessarily a bad thing, just that if the dealer near you closes down, and you need to get reflashed, then you might have to travel a very long distance. And if the shop is small, then they might close down, in which case, you’re essentially SOL if you needed a reflash.
Where to Get it Installed?
-The chip can be installed at any dealer who distributes the chip that you are looking for. Also, please read the section ”What chip should I choose”. For reference, I have linked to the dealer locators:
APR: http://www.goapr.com/VW/dealer/locator.php
GIAC: http://www.giacusa.com/dealermap/
Revo: http://www.revotechnik.com/loc....aspx
Unitronic: http://www.unitronic.ca/uni/content/section/4/26/
Neuspeed: http://www.neuspeed.com/dealer..._euro
Price
*Notes
-I rounded some of the numbers to make it easier to add.
-All prices are in USD, UNO.
-Prices do not include the dealer installation fee, which typically range from free to $100.
-Sometimes you can save some money by buying it at the show, or when they have sales.
-Prices are list price only. Dealers have some leeway with regards to giving discounts, so check with your local dealer.
The base price for a pump gas chip is as follows:
APR: $600
GIAC: $550
Neuspeed: $500
REVO: $500
Superchips: $ £600 (~$1200 USD)
Dahlback Racing: 890 EUR excl. VAT (~$1300 USD)
SpeedTuning: $300
O.CT – Price not listed on website
Unitronic – $550
Additional programs/items can be added
APR addons:
2 programs (i.e. stock & chipped) $150
3 programs $220
4 programs $290
Fault Code Erase/Throttle Body Alignment (FCE/TBA) $100
Security Lock-out $60
Anti-Theft System $200
Stage 2 software (for those with a downpipe) – no additional charge
GIAC addons:
Stock $50
Race 100-104 octane $100
Kill $50
Valet $50
Security Firewall $100
Handheld Flashloader (to allow switching) $150
Neuspeed:
Neuspeed does not offer any additional programs.
Revo:
Revo Select $200
Revo Select Plus $350
Stage 2 software (for those with a downpipe) $50
Unitronic addons:
Stage 1+ $50
Performance:
Note:
APR
GIAC
REVO
Unitronic
245hp/277lb-ft
Dahlback Racing
SpeedTuning
O.CT
Price
*Notes
APR: $600
GIAC: $550
Neuspeed: $500
REVO: $500
SpeedTuning: $300
Unitronic – $550
APR addons:
3 programs $220
4 programs $290
GIAC addons:
Stock $50
Kill $50
Valet $50
Neuspeed:
Revo:
Revo Select $200
Unitronic addons:
Stage 1+ $50
