Shifter play on transmission side
zrickety
The Fixer
Ride
09 GTI
I posed this question on the MK6 forum, but maybe you guys have more experience. I did the linkage adjustment yesterday, and there was a lot of play on top of the transmission. The cast arm was moving quite a bit independently of the shaft coming out of the trans.
Is it the cast piece worn out, or the shaft? I was able to use a washer to stiffen it up, but I'm sure there is a better fix.
